#61 | |
You will still need to wire the high speed through the 80 amp 100% duty cycle relay as the high speed cannot be run by the thermostatic switch. (that is only 30 amp)
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife) 1946 CJ2A, 225 V6. mild lift - TIME TESTED 1966 M416 1/4 ton Military Trailer -- WAR TESTED Full Page Club member #004 Green Jeep Club Member #005 |
#62 |
OK, so your saying I should take back my ford starter relay that was posted earlier?
**LOOKING FOR MY JEEP, LAST SEEN IN CT and CURRENTLY HAS CT PLATES White 1996 Grand Cherokee Laredo, I6 4.0 20% tint all around **KOR Radiator Support, IRO 3.5" lift, 31/10.5/15" Maxxis Bighorns on 15x8 Cragar Soft 8's, JKS Bar Pin Eliminators, KOR Light Bar, 4 Black KC HiLites, Flowmaster Super 44 with turndown/no tailpipe, OME Steering Stabilizer, Black KOR square rock sliders **If youve seen it around CT or know about it, PM me |
#63 | |
Here are the stats on the Bosch Relay, though these have failed too I hear, just not NEAR as often 12 volt high amp power electrical relay 75 AMP - Tyco / Bosch 0 332 002 150 # tyco v23232d0001x001 / 1904000-1 # with bracket # 4 terminal dual contact # 75 amp - 100,000 cycles # Motor load: Normally open 60 amp / 400 Amp inrush @ 40,000 cycles # SPST, dual contact # Resistive load Normally open: 100 amp - 100,000 cycles # Contacts: Silver Tin oxide # Coil operating current 290 mA # Equivalent coil resistance: 46 +/- 3 ohm # Pull in voltage:<= 8.0V # Drop out voltage: 1.5 - 4.0 V # ELV compliant # replaces cole hersee: ra-700112-nn # replaces Potter & brumfield: vf7-11f11 # replaces Bosch 0-332-002-150
#64 |
GSMW!
DTrem, yes, the yellow tracer is for high, the orange tracer is for low, and the solid black (no tracer) is ground
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#65 |
Hmmmm....
Would a Cherokee fan work for being swapped in as well? I'm really considering doing this before I go to Silver Lake this summer in early June. I kinda want a Tranny cooler as well, but I don't think I need it as much...but i'm in between this two mods right now anyways and what I really want/need to do.
#66 |
This is probably dumb question and probably has already been covered, but on the fan itself does it bolt right to the radiator or are there some mods required?
1995 Limited 5.2L with 170K Stock for now |
#67 | |
Mods are required, fabbing brackets for the most part. Pretty easy to do though.
#68 |
Hmmmm....
Alright. I think i'm going to end up doing both before I go anyways. I have about 5 weeks or so before I leave, 2 of which will be out of school so I will only have to work during the day. Now I need to find a cheap Taurus fan and the wiring - already planned on ordering a B&M Tranny Cooler from Summit.
Edit: Will the Bosch relay on the bottle on this page work? http://www.wiringproducts.com/index1.html Or should I find something else? Last edited by _Kyle_; 04-22-2008 at 02:29 PM.. |
#69 |
Very happy to join this forum, I guess I found all what I was looking for in this site specially cooling and overheating issues on ZJ's.
Great post, wonderful job Tim, lots of info from the posted replies, I just wanted to know if I could install this electric fan on my 93 ZJ laredo, 4.0L. Thanks. |
#70 | |
zj tractor
i dont see any reason you couldnt put this on a 4.0.
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#71 |
ZJjazzyJim
You can definitely put it on a 4.0, but my understanding is that you might have some clearance issues. It has been done, but some creative "carving" had to be undertaken on the Ford shroud.
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#72 |
wow man this is great i am gonna be doing this upgrade next week before my pismo trip. Now with this fan you are supposed to be getting better hp and mpg is this true?
Alonzo
Alonzo "Casper" Gonzalez 1993 Jeep Grand Cherokee Laredo 4.0L Engine w/ 231 TC IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount Bilstein 5150 shocks JKS Quick Disconnects JCR 1 Ton steering Addco Front Sway bar Flowmaster muffler K&N air filter 2 Pro Comp 2 KC lights on KOR light bar Coleman roof rack Coming Soon! Gears and locker! |
#73 |
you free up some...but not much...don't expect great things. Kind of like running on tires that are under inflated. You air them up and you get better mileage and feel that the engine isn't sluggish to get going...that is all.
96' JGC V-8 5.2L ltd. way too much to list. Thought for the day: If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day. [URL]http://photobucket.com/albums/v639/nashmd454[/URL] [url]http://groups.jeepforum.com/The_Dark_Side[/url] |
#74 |
i dont get the reason behind this install? i know that when your driving slow and using lots of engine torque and under heavy load the mechanical fan cannot draw the air to cool properly. so an electric one is in order. but why a taurus electric fan ? why not get a slimline puller s-blade fan from derale and use both ? or find a dakota s blade fan in the junkyard? my dads dakota has both from the factory and the electric fan is only used for the air conditioning. i have seen a few used jeeps come through my dealership and saw that the cooling fan was hydraulically actuated that was a sight to see. i say keep the regular fan and add the slim puller or pusher fan if front of the condenser. rather than add tons of extra wiring run one relay and one temp. sensor done! some of the 99-01 jeep electric cooling fans stop working because the dielectric grease dries out and then it overheats and fries the transistor. then the engine overheats because the fan wont turn on.
WHY DO YOU NEED TO KNOW WHERE YOU ARE GOING? |
#75 |
@ Heap-O-Jeep:
I believe that the taurus fan pushes a hell of a lot more CFM's than the stock fan. Plus, with the availibility of the fan, its a popular swap.
Im a student and unemployed and have a Haynes. //93 ZJ//5.2L//NP249//K&N Fipk Gen II//2" BB w/BD AT Shocks//4.10's//31" Cooper Discovery STT's//Cstm Frnt Bmpr//Custom Rear Tube Bmpr//3" Magnaflow exhaust w/high flow cat//500RMS Pioneer Amp//600RMS 12" JL Audio Sub//4 Hella 500's on Cstm Light Bar//Sealed Intake Box w/ ram air// |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
