Ford Taurus Two Speed E-Fan Install (pics)
#46 | |
Belief In All Things Jeep
Speaking from years of experience playing with electric fans in the hot desert, I think the fan should come on LOW pretty quick, around 180-190, and stay on continuously unless you are out on the freeway. Otherwise there is no air moving in the engine bay and everything gets real hot. If you think about it, a clutch fan turns all the time. It takes a lot adjusting to get the thermoswitch set just right so the fan turns off at freeway speeds and stays on around town and out wheeling.
#47 |
So your saying I should just have it on low all the time and maybe turn it off manually when the cars just warming up?
**LOOKING FOR MY JEEP, LAST SEEN IN CT and CURRENTLY HAS CT PLATES White 1996 Grand Cherokee Laredo, I6 4.0 20% tint all around **KOR Radiator Support, IRO 3.5" lift, 31/10.5/15" Maxxis Bighorns on 15x8 Cragar Soft 8's, JKS Bar Pin Eliminators, KOR Light Bar, 4 Black KC HiLites, Flowmaster Super 44 with turndown/no tailpipe, OME Steering Stabilizer, Black KOR square rock sliders **If youve seen it around CT or know about it, PM me |
#48 |
#49 | |
You WILL forget to turn it on at some point!!! Use a thermostatic switch for low, and set it at around 160* (mine is set to come on at 90* but mine heats up VERY fast) High and off are the only "manual" switch settings.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife) 1946 CJ2A, 225 V6. mild lift - TIME TESTED 1966 M416 1/4 ton Military Trailer -- WAR TESTED Full Page Club member #004 Green Jeep Club Member #005 |
#50 |
OK, but where do I get this switch and how do I wire it up??
Heres the picture for the other question, its a MS paint reproduction of what the top of the relay says, my camera wouldn't take a clear enough picture ![]()
#51 |
If it helps, here is a write up I did on my Taurus fan install. Shows the switch I used with the NAPA part number.
http://www.jeepforum.com/forum/f12/taurus-fan-install-312027/
#52 |
I might have missed it, but the only two part numbers I found were for the switch in the cab and the 75 amp relay
#53 | |
Advance Auto Parts Hayden Fan Control Kit Part Number: 3647 Or Hayden Fan Control Part Number: 3651 You can use others.... but those are available off the shelf.
#54 |
Ok, Ill see if I can pick one of those up
anybody know anything about wiring up that relay with the diagram above?
#55 |
yeah, are you gonna use a temp sender to turn it on or a switch?
Brad 2004 Wrangler X 2001 Grand Cherokee Ltd. 1997 Grand Cherokee Ltd. |
#56 |
Couple of my writeups
http://www.jeepforum.com/forum/f13/e-fan-controller-schematic-467329/?highlight=ford http://www.jeepforum.com/forum/f13/ford-3-8-efan-project-begins-355400/ One thing I will say is if you do the efan wrong, you can overheat and ruin your motor...so the project is nothing to sneeze at. |
#57 |
Im just going to have it so its always on low with a manual override for high
#58 |
All I need now is a little help wiring up that relay and I should be good to go
#59 | |
I wouldn't leave it on low all the time, you really should use the thermostatic switch controlled by the in cab three way switch, it moves enough air that your motor might never warm up properly, and a cold running motor is in efficient and can start burning out sensors (O2) and if you run your cat converter can ruin that too.
#60 |
Ok I'll have to look into pickin up one of those hayden kits then
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
