Ford Taurus Two Speed E-Fan Install (pics)
#31 | |
I picked up my fan for 10 bucks today
![]() Got the 10ga wire and the 30 amp relay, gotta get the stuff for high so I can do this Which wires are which coming out of the Taurus fan? Also, how would I go about setting this up to come on only when it reaches a certain temperature?
**LOOKING FOR MY JEEP, LAST SEEN IN CT and CURRENTLY HAS CT PLATES White 1996 Grand Cherokee Laredo, I6 4.0 20% tint all around **KOR Radiator Support, IRO 3.5" lift, 31/10.5/15" Maxxis Bighorns on 15x8 Cragar Soft 8's, JKS Bar Pin Eliminators, KOR Light Bar, 4 Black KC HiLites, Flowmaster Super 44 with turndown/no tailpipe, OME Steering Stabilizer, Black KOR square rock sliders **If youve seen it around CT or know about it, PM me |
#32 |
Also, what type of fuse should I use? Also, what exacltly does the relay do, and I'm a bit puzzled by how to wire it up. It's got 5 pins on it, thats about all I know...
#33 |
Anyone?????
#34 |
ZJjazzyJim
For a 30 amp relay, a 30 amp fuse would be beneficial, I presume.
Black is ground, and I want to say yellow tracer is the high side of the fan. Jump it straight to the battery to identify. It won't bite...too hard Just make sure you have a good hold of the shroud - fan will try to jump when you find the high side...sucker's fast ![]()
Jim Karlin "How the heck do you get there?" "Duh! Big RED Jeep!!!" Best customer service in the states: Best mod you'll ever do on ANY vehicle!!!!
#35 |
Ok....I got the 30 amp relay....5 pins on it, no clue how to hook it up. No instructions included. Looks like the one in the picture in the instructions....thats all thats holding me up now
#36 |
ZJjazzyJim
What part number is on the relay? Gotta be a schematic online.
#37 |
how do you want to activate the relay, a switch?
Brad 2004 Wrangler X 2001 Grand Cherokee Ltd. 1997 Grand Cherokee Ltd. |
#38 |
Yes, I have an on-off-on switch that I will be putting in the console area.
Also, anybody know about getting temperature sensors or something so it only runs when it has to? I will get a picture of the relay up tomorow
#39 | |
you proably have a bosch spdt 85>86 30>87a,87
#40 |
you'll want to sequence that temperature sensor with your T-stat opening temp. so that your stat will be open wide or close to it before the fan comes on, that way you will be utilizing all it's potential, but if you bring on the fan too early your stat will never open.
#41 | |
as long as the fan comes on sometime before the t-stat opens you're ok.
#42 |
You just explained that point perfectly. It doesn't.
#43 |
sorry, i confused myself
![]() if the fan comes on too early the tstat will never open? i'll have to disagree
#44 |
yea your thinking is ok, and I'll agree it won't make much differance other than your running that power eater for nothin, till that stat does open.
say your stat @180 begins to open, wide open @ 190 maxed out You'll want the fan to come on somewhere in that same range. It just makes more efficient use of the cooling system. IMHO. |
#45 |
So if I have the stock TStat in my zj, what temperature would I want the fan to come on at and how would I go about wiring it?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
