Ford Taurus Two Speed E-Fan Install (pics) - Page 17 - JeepForum.com
post #241 of 244 Old 07-30-2015, 09:41 AM
Billyjoebob007
Originally Posted by blakesgst View Post
Kg, do you have a part number you can share for the volvo relay pack and bmw temp switch?
I am still trying to figure out what the easiest method is, appears to be a lot of different options for what electronics are used to control the fan. Jegs and Summit also have a lot of controllers but I don't know what the best bet would be going that route, anyone purchase a controller setup from them and if so, what one?
Thanks,
Blake
The volvo relay is 9442933 , bmw temp switch is 61311378073 .
Heres a couple other threads that are worth a look:
http://www.jeepforum.com/forum/f12/v...-swap-1373350/
http://www.jeepforum.com/forum/f13/t...relay-1526807/
http://www.jeepforum.com/forum/f12/a...ic-fan-390317/
http://www.jeepforum.com/forum/f13/n...l#post23637601
Billyjoebob007 is offline
post #242 of 244 Old 07-30-2015, 11:24 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yep, part numbers are correct. I found both very quickly in the JY.
For simplicity (a good thing IMO) the volvo setup is very nice. It emulates the way the original niner fan was controlled pretty well. The BMW thermoswitch is much more reliable (if you get a real one) than a lot of the temp sensors used by the electronic controllers.
kg6mov is offline
post #243 of 244 Old 07-31-2015, 11:52 AM
blakesgst
Thanks guys! Will the BMW switch turn the fan on high at a certain temp or do you need 2 switches?
Blake
blakesgst is offline
post #244 of 244 Old 07-31-2015, 12:20 PM
kg6mov
Hears the voices
kg6mov's Avatar
The BMW switch is two switches in one. Low speed at around 203* and high speed a little over 212*.
kg6mov is offline
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 10:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 01:27 PM
finally installed my ford taurus fan MEinSoCal ZJ Grand Cherokee Forum 12 08-11-2008 06:13 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 07:49 PM
Ford Taurus 2 Speed Fan Swamp Boy ZJ Grand Cherokee Forum 11 01-13-2004 02:38 PM
