Ford Taurus Two Speed E-Fan Install (pics) - Page 14 - JeepForum.com
post #196 of 244 Old 09-06-2012, 10:05 PM
FPKites
ZJjazzyJim
FPKites's Avatar
1. When the stock shroud is used (as has been mentioned in this thread), you get better airflow in a pull situation than you ever would in a push.
2. If you really want to test it when using the AC full blast, either wire it so it goes to full amperage when the AC is turned on, or install a bull **** switch as I did. Either way, get the fan going as fast as you can for optimal cooling of the engine and the AC
3. Your tranny being hooked up to the radiator, going out or not, will not add to engine heat....unless your tranny is so bad it's shooting fire through the cooler lines
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #197 of 244 Old 09-06-2012, 10:35 PM
Gcnettl
Pushing is a good way to lower your condenser temp but little else.
I'm thinking of installing a small pusher fan to the driver side of my condenser, just to help with condenser cooling.
Gcnettl is offline
post #198 of 244 Old 09-07-2012, 01:37 PM
JustinW23
We have 4 large junkyards here with loads of Taurus's but every one of them has had the cooling fans ripped off. I think we have reached the end of our pool of used Taurus fans. There is a huge off road scene here however. One of the junkyards said that the "Stupid Jeep guys" took all the fans. I didn't tell him that it was for a Jeep.
'98 ZJ 5.2 6" Long Arms, 265 75R 16's, Magnaflow Cat and Super 40, Taurus Fan Swap
JustinW23 is offline
post #199 of 244 Old 09-07-2012, 02:58 PM
moggie99
New Taurus fans (with shroud) are only $84 apiece at Rockauto.
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #200 of 244 Old 09-07-2012, 03:20 PM
JustinW23
I was able to locate a Taurus this afternoon that still had the fan in it. The motor was already pulled. I don't know if the motor was the 3.0 or the 3.8. What is the difference between the fans? I took a gamble and bought it for $25. It looks just like the 3.8 fan. Will it work if it ends up being the 3.0 fan?
post #201 of 244 Old 05-11-2013, 04:40 PM
970001zj
i got the mk-8/t-bird e-fan , it pulls more air and draws a little more amps on high , perfect fit on the radiator
thanks for the heads up on the starter relays
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #202 of 244 Old 05-11-2013, 10:15 PM
PeteNnewburg
The 3.8 Taurus fan is 2 speed, 3 wire. The 3.0 is a 2 wire fan. I think the 3.8 fan is also larger in circumference. I just picked one up off eBay, item # 230976486756. If it looks like that, should be a 3.8 2 speed fan. No local yards had one and this item looked really nice. Seller Doug was very helpful!! This is one of his specialties!
I will be useing the DCC FK-55 controller. A bit pricey, but one and done. http://www.dccontrol.com/constant_te...ontrollers.htm. It has a lot of very good reviews.
Pete
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #203 of 244 Old 05-11-2013, 10:51 PM
FPKites
ZJjazzyJim
FPKites's Avatar
You can't go wrong with the DCC controller in my opinion. I've had my FK35 for about 5 years, and it's still going strong. I thought it was dying about a year and a half ago, but it was just corroded butt splices. Replaced them with waterproof ones, and it's running perfectly.
Brian makes a great product, and I'd recommend it to anybody. Lead time has been long in the past, but I don't know what it's like now.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #204 of 244 Old 09-22-2013, 11:27 PM
justbob
what temperatures should the low and high speed fan come at and shut off at ?
95 ZJ 4.0, Auto, AC
Once you can accept the universe as being something expanding into an infinite nothing which is something, wearing stripes with plaid is easy
justbob is offline
post #205 of 244 Old 09-23-2013, 08:47 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
95 ZJ 4.0, Auto, AC
No expert, but I would guess lo 200, hi 220. If you go lower than thermostat rating, the fan won't turn off.
HighLonesome is offline
post #206 of 244 Old 09-20-2014, 08:17 PM
Staticat
I am doing this to a 1997 2.5 wrangler I was wondering if mine will have the same blue and gray wire? I bought a kit that I need to tap a wire into my ignition switch. Thanks
Staticat is offline
post #207 of 244 Old 11-13-2014, 08:13 PM
SweetPEALvr15
Originally Posted by tj2kj View Post
Got the PT Cruiser fan installed with about 1/2" to spare between engine and fan motor. Works well. Installed switch on dash to go low/off/high. Wanted to be able to turn off for quick warm ups in cold weather and for water crossing. I installed 2 LEDs on dash above instrument panel that will illuminate when the engine is on and the fan is off. Had to use 2 relays for the fans I located in a small box under the hood fastened to the firewall and 2 more relays under the dash for the LED control. When installing it I discovered altough the fan was out of a 2002 PT Cruiser, it was a replacement unit only 1 year old. Sweet!
I cut the original fan shroud a little and trimmed the Cruiser fan shroud and bolted them together. Then shoved the assembly between radiator and engine and locked it down using the original mounting points of the Jeep shroud. Engine seems to operate better as does the AC.
beautiful! definitely gonna do this!!!!! the Southwest isn't kind to these engines come summer time. Quick question though, can't you remove the stock fan shroud since the PT cruiser one already pretty much has one? or does it not cover the jeeps radiator well enough?
SweetPEALvr15 is offline
post #208 of 244 Old 11-14-2014, 09:53 AM
tj2kj
I wanted to use the stock shroud to insure it covered the radiator well and make it easier to mount. Cutting it to fit the new fan was pretty easy. Fan is still doing the job.
tj2kj is offline
post #209 of 244 Old 11-15-2014, 01:43 AM
kg6mov
Hears the voices
kg6mov's Avatar
You want maximum fan shroud coverage, its a big deal.
The lincoln mark VIII fan and shroud is a close fit, as is the t-bird.
kg6mov is online now
post #210 of 244 Old 07-23-2015, 01:21 PM
blakesgst
Old thread I realize but this appears to be an ongoing suggested upgrade and I have a question. Any reason to not have this fan running all the time in low, with maybe a switch to bump it to high if need be?
Thanks,
Blake
blakesgst is offline
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 11:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 02:27 PM
finally installed my ford taurus fan MEinSoCal ZJ Grand Cherokee Forum 12 08-11-2008 07:13 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 08:49 PM
Ford Taurus 2 Speed Fan Swamp Boy ZJ Grand Cherokee Forum 11 01-13-2004 03:38 PM
