> Models
> Jeep Grand Cherokee & Commander Forums
> ZJ Grand Cherokee Forum
Ford Taurus Two Speed E-Fan Install (pics)
06-04-2011, 11:13 AM
#181
On the 5.2 how does the water pump pully stay on when you pull off the fan? On mine it looks like the only thing holding on the pully is the fan..........
1996 Jeep ZJ Orvis
[QUOTE=Matchbox2000;12071961]
Glad to know the foreskin guy is gone! Thanks for the tip! ;-)
[/QUOTE]
03-19-2012, 11:22 AM
#182
Czech OffRoader
So I found out my 5.9 has the Taurus e-fan already installed, but I don't have a switch controlling the speed. It looks like it is wired to the existing hookup for the stock e-fan.. So does that mean my ZJ does it automatic for me?
Also, I would need to buy some steel strippings and make my own mounting brackets.. the previous owner has zip-ties holding this one...
1998 ZJ 5.9L Limited - Platinum
Upcoming Projects: Digital Camo Paint Job mod , 4.5" IRO lift kit w/ 2" BB Pucks + RE 8 Adj. Arms , Front + Rear Bumper fab. w/ Winch, Tire Mount & Cargo Gas Tank holder
R.I.P
1997 ZJ 5.2L V8 - Mud Flooded the Engine - Donor Jeep now
Originally Posted by McCloudsZJ
I named mine Jezebel because she used to be the most powerful thing in the world, but now shes just an old, dirty ***** whose been around the block a few times.
03-19-2012, 12:31 PM
#183
The 5.9 fan has two settings that are temperature controlled automatically.
98 5.9 2"BB, Custom V-Tec mod, high performance muffler elves, alloy performance lug nuts, super high flow custom radiator cap, Ultralight unobtanium flywheel, stage 6 ultralight hydro tuned wiper blades(front), kevlar stickers
[QUOTE=JohnnyZJ;13325401]if its to tall for her to get into why don't you just install some running boards?[/QUOTE]
[QUOTE=HAMAR;13330720]I just gave her ironing board, she's not getting another board.[/QUOTE]
"What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentations of the women."
03-19-2012, 04:56 PM
#184
ZJjazzyJim
The water pump pulley is pressed on. The big nut that you see secures the fan clutch to the WP.
The 5.9 fan is theromstat-controlled by a (very expensive to replace) sensor in the upper (and lower?) radiator hose.
As it turns out, the motor for the 5.9 is the very same one in the 3.8l Taurus. 2 speeds. The blades are a smidge different, and the shroud is obviously different.
What he said
Jim Karlin "How the heck do you get there?"
"Duh! Big RED Jeep!!!" Best customer service in the states:
Best mod you'll ever do on ANY vehicle!!!!
06-04-2012, 10:43 AM
#185
I've probably missed it here, but what are you guys using for the circuit breaker and where do you get it? Can you just use a higher amp inline fuse for this?
1995 YJ: 4.0L I-6 and AW-4 trans; CJ front clip; SOA front, 4-link in rear; 8.8 rear w/ Detroit locker; 4.56 gears; TJ front shafts; SYE; 1" Body lift; JB4x4 hi-steer; Ford Taurus fan; B&M Hi-Tek trans cooler; 35" Procomp MT on aluminum wheels
06-04-2012, 10:52 AM
#186
I used an inline fuse.
06-21-2012, 08:14 AM
#187
Thanks!
1998 ZJ Laredo(Gonzo) - Built Not Bought - 3.5" lift with IRO Long Arms, Cherry Bomb Exhaust, 31x10.50R15, CAI, Custom Front Recovery System & YJ Tube Bumper
1986 Toyota MR2 - Polyurethane Suspension Bushings,Suspension Techniques Lowering Springs,S/C Swap and more!
07-12-2012, 04:20 PM
#188
I saw some reference to using the Taurus fan on a 4.0L ZJ - it won't fit. Found out the hard way. You only have about 3.5" clearance between the radiator and the water pump pully - too narrow for the fan. Fortunately I got a warranty on the Taurus fan at the junk yard, so went back to search for another that would work better. After a bit of searching I found a 2002 Chrsyler PT Cruiser has a 3" wide X 16" fan in a nice housing that looks like a great fit. It also is a 2 speed unit. I post a pic when I get it installed this weekend.
07-17-2012, 07:23 PM
#189
Got the PT Cruiser fan installed with about 1/2" to spare between engine and fan motor. Works well. Installed switch on dash to go low/off/high. Wanted to be able to turn off for quick warm ups in cold weather and for water crossing. I installed 2 LEDs on dash above instrument panel that will illuminate when the engine is on and the fan is off. Had to use 2 relays for the fans I located in a small box under the hood fastened to the firewall and 2 more relays under the dash for the LED control. When installing it I discovered altough the fan was out of a 2002 PT Cruiser, it was a replacement unit only 1 year old. Sweet!
I cut the original fan shroud a little and trimmed the Cruiser fan shroud and bolted them together. Then shoved the assembly between radiator and engine and locked it down using the original mounting points of the Jeep shroud. Engine seems to operate better as does the AC.
07-17-2012, 08:26 PM
#190
ZJjazzyJim
Very nice!
08-23-2012, 05:10 PM
#191
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
Went back to the boneyard looking for a bank of relay sockets (small footprint) and I found two more 70/80 amp relays for free with a more contemporary number;
I scanned several vehicles for small footprint relay pods, but so far those that take Bosch style relays are 6x9" and larger.
The more people I meet,
the more I like my dog.
08-30-2012, 03:20 AM
#192
I've been looking a this whole issue for some time now and trying to decide what to do. As I see it my options are:
1) second hand Taurus fan - not that easy to find out here in the UAE because the Taurus isn't a common car
2) new Taurus fan assembly from Rockauto - $84 including shroud. That would require shipping but it is new
3) keep the standard Jeep shroud and fit a universal fan into it.
By my measurements the aperture in the existing shroud has a 19" diameter and could be trimmed to give about 20" I would guess. On my Jeep I have just under 4" from the rear face of the radiator to the front of the pulley (after removal of the mechanical fan and clutch)nso that should be OK depth wise.
Looking at the info on Rockauto, the Taurus fan appears to have a diameter of about 16" and that is about the size of the largest fan that Spal list on their website. Looking on eBay, that does seem to be about the maximum diameter available (apart from a few ridiculously expensive Flex-a-Lite items).
The 16" Spal promises about 1900CFM - does anyone know what the output of the Taurus fan is? I've seen 16" universal fans on eBay promising 2000CFM+ but I'm not sure if I really believe those figures!
I'm tempted to try a 16" universal one, though, (lower cost option, especially with regard to shipping) and if that does not cut it then I'll front up the money for the Taurus fan. For simplicity I would probably just wire it up to run permanently, given that it never really gets cool here - even in "winter".
Richard Moss
1996 Grand Cherokee 4L Laredo. Ongoing "project": [url]http://www.jeepforum.com/forum/f197/richard-mosss-1996-gc-zj-4l-laredo-1356317/#post13406000[/url]
1995 Cherokee XJ 4L manual
Back in the UK: 1969 MGC GT
09-06-2012, 10:55 AM
#193
Would I have the air from the fan pushing through the radiator or pulling through it?
09-06-2012, 08:35 PM
#194
ZJjazzyJim
I would use a Taurus fan as a puller.
09-06-2012, 08:44 PM
#195
I had it pushing and it was overheating. So I posted on another thread and. They said have it pull so I have it pulling now and it works great so far. Have only drove it to work but it kept it cooler the whole way here. It would heat up a little on start offs but it went right back when I was going. I have to test it standing still with the a/c on full blast. My tranny is going out and It is still hooked up to the radiator so it likes to heat up my engine as well.
