Ford Taurus Two Speed E-Fan Install (pics) - Page 11 - JeepForum.com
post #151 of 244 Old 03-07-2011, 05:01 PM
SA59GRAND
Don't know if anyone has heard of this one but I found it on Ebay and it sounds good and runs 2 different speeds if you have a 2-speed fan. http://cgi.ebay.com/ebaymotors/ws/eB...m=370503454034
SA59GRAND is offline
post #152 of 244 Old 03-07-2011, 10:03 PM
mike_breaker_5
subbed for future reference.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #153 of 244 Old 03-08-2011, 11:05 AM
Fixins13
Whoa, isn't the idea here that this is cheap? Is that fan control $125? I bought a general purpose electric fan for about $50 and then this thermostatic switch kit for $25 and never touched it again. I put a kill switch in the cockpit in case I was crossing water and that was it. 2-speeds are nice and all but wouldn't you rather it just work?
I love sleep. My life has the tendency to fall apart when I'm awake, you know?
Ernest Hemingway
Fixins13 is offline
post #154 of 244 Old 03-08-2011, 05:55 PM
Jeepfreak81
Jeepfreak81's Avatar
Your $50 fan does not flow near the amount of air the Taurus fan does. OEM parts also generally will last MUCH longer and take much more abuse then an aftermarket part. A comparable aftermarket fan to the Taurus fan will be MUCH more expensive then $50
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #155 of 244 Old 03-08-2011, 06:24 PM
SA59GRAND
Yea I have to go with Jeepfreak81 on that! No $50 fan is going to flow anything like the Taurus fan, unless it is a used Taurus fan and for that price the motor is probably pretty tired in it. I wanted even more flow that the Taurus fan so I tried and fitted a Lincoln Mark VIII 18" into my 1998 5.9 ZJ. http://www.flickr.com/photos/4010925...7624589707277/ and before that I replaced the wore out Factory 5.9 fan motor with a Siemens fan motor from Autozone and wired it to a 2-way switch on my dash. http://www.flickr.com/photos/4010925...7620884087193/ So when I changed to the 18" Lincoln fan I just changed the wires over to that fan.
post #156 of 244 Old 03-08-2011, 07:45 PM
Fixins13
My $50 Flex-a-lite fan and $25 switch lasted 2+ years until I sold that particular Jeep. It never once went into the red on the temp gage and I never touched the control once I had it set where I wanted it. I'm not trying to be argumentative; y'all should mod your rigs any way you see fit. If you want to spend the money to have a digitally controlled, 2-speed, Ford made, 30 amp fan, have at it. I guess my only point was I did it for less money and seemingly a lot less effort than some say they needed to make a junkyard part work reliably in their Jeep. Also FWIW, I ran the ground on the relay through the firewall so in case it shorted, the fan would come on rather than vice-versa.
Ernest Hemingway
Fixins13 is offline
post #157 of 244 Old 03-08-2011, 08:55 PM
Jeepfreak81
I run a mild 355 in my rig, I tried the cheapy $50 fan... I yanked it and tossed it on my flatfender. The Taurus fan dropped my temps 15-20* because it could get ahead of the heat the motor produces.
post #158 of 244 Old 04-20-2011, 01:11 PM
1997ddzj
OK guys im apparantly retarded. I cant seem to find the right fan. My first trip led me to getting one out of a 1990 taurus wagon that didnt fit. The motor on the fan was way to large to fit. No big deal, I have a warranty for it so I took it back. Well I get another fan out of a 1995 Taurus, with the correct part number as the one off of the mall crawling write up. Well this one does not fit either.
Now it very possibly could be me, but there seems to be something wrong here. This fan does not fit on the radiator at all. Its acually wider, A good inch on each side. Now when i was at the yard I did notice a 3rd style of fan, but it was on the newer generation and they had two fans instead of one.
Anyone got some insight?
1997ddzj is offline
post #159 of 244 Old 04-20-2011, 02:47 PM
SA59GRAND
In post number 4 he said that he had to mount it Up-Side Down to Clear the Power Steering Box. Did you try it that way??? Look at post #197 on this page http://www.mallcrawlin.com/forum/sho...us-fan../page8 , he fit it into the Factory V8 ZJ Fan Shroud. Does your fan look like that one??? Also read through the Whole thread, they are talking about mounting it on the Lower part of the Radiator because it slips into the 2 "notches" on the bottom of the Radiator and then using metal strips to attach it to the Top of the Radiator. Something like this http://www.flickr.com/photos/4010925...7623987014061/ Hope that helps.
post #160 of 244 Old 04-20-2011, 04:20 PM
1997ddzj
Yes Ive had it every which way. Upside down, right ways, even had it vertical at one point lol. Ive had it down to the bottom of my radiator and it def does not clip in. Im pretty sure I have the wrong fan, as this one does not even fit inside the end tanks of my radiator. i for sure got it our of the right year range, and it had the correct engine, so im not sure what the deal is. Nor how this proplem hasnt come up with somebody else.
From looking at that picture though, it does resemble my fan how its offset from the center. But mine has about 5 more inches of offset lol.
1997ddzj is offline
post #161 of 244 Old 04-20-2011, 05:47 PM
FPKites
ZJjazzyJim
FPKites's Avatar
The fan you're looking for is a single, and it has 3 leads coming out of it. It clears my 5.2 with the mechanical fan perfectly.
If anything, it would be good to overlap the end tanks on your radiator. Protect the fins and get a decent seal.
I said it many moons ago, and I'll say it again...get the fan from the 3.8
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #162 of 244 Old 04-20-2011, 06:26 PM
1997ddzj
The one I have IS off of a 3.8 taurus. Unless people are modding them this one does not fit. Nor did the previous one. Hasnt anyone come across this problem but me? I seriously feel like a complete moron trying to figure this out.
And im sorry Im not looking to be spoon fed here either. I dont expect to have that nor do I want to learn that way. Im just incredibly suprised that no one else has come across these different style fans before.
1997ddzj is offline
post #163 of 244 Old 04-20-2011, 08:07 PM
FPKites
ZJjazzyJim
FPKites's Avatar
It's possible that the 4.0 makes it hard to fit. My only experience is with the 5.2.
What exactly are you not able to clear?
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #164 of 244 Old 04-20-2011, 09:22 PM
SA59GRAND
1997ddzj........Check the Measurments on the fan you have with the measurments of this 3.8 V6 Taurus Fan. http://www.broncoii4x4.com/taurus-fa...taurus-fan.php
post #165 of 244 Old 04-21-2011, 11:49 AM
1997ddzj
Thanx for the help guys. I ended up getting the correct one today out of a S.H.O. Which I know isnt what it was suppose to some out of, but it is the exact one that everyone has been using. So apparantly someone has swaped this fan at some point lol.
1997ddzj is offline
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 10:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 01:27 PM
finally installed my ford taurus fan MEinSoCal ZJ Grand Cherokee Forum 12 08-11-2008 06:13 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 07:49 PM
Ford Taurus 2 Speed Fan Swamp Boy ZJ Grand Cherokee Forum 11 01-13-2004 02:38 PM
