Ford Taurus Two Speed E-Fan Install (pics) - Page 10 - JeepForum.com
post #136 of 244 Old 09-12-2010, 01:41 PM
Billyjoebob007
Originally Posted by scubatch2 View Post
Thanks for the write up,I was planning on doing this in the next few months
Heres these ones that are still 12V 55W but like $100 cheaper than the 1000's:
Hella 005750991 500 Series 12V/55W Black Magic Halogen Driving Lamp Kit
Amazon.com: Hella 005750991 500 Series 12V/55W Black Magic Halogen Driving Lamp Kit: Automotive
Billyjoebob007 is offline
post #137 of 244 Old 09-12-2010, 01:43 PM
Billyjoebob007
Jeesh, i just posted the above to the wrong thread
I have 3 jeep forum tabs open and i gots confused
post #138 of 244 Old 09-29-2010, 08:03 PM
JKDinSC
So i have a 4.0 zj would like to swap in an e-fan. I want it to turn on and off automatically but would like to have an override switch to make and turn it off if water crossing. so what all exactly will i need? like what size realays would a taurus or contour fan work better and how can i wire it to have it turn on and off as i stated above, any help would be greatly appreciated
JKDinSC is offline
post #139 of 244 Old 09-30-2010, 05:29 AM
YelloJeep
I would recommend getting some relays from a junkyard (3 or 4 of them) out of a cadillac. That is what I did. They were cheap and they had waterproof housings on them. I don't know what size they were but I have had no problems. The relays were mounted on the firewall (on a little bracket with 3 relays) or the driverside fenderwell. I don't remember. I believe you will need 2 of the relays to set it up the way you want it (the diagram I used was set up for that) and the extras are for spares. Oh, and I think I had to rob a wire off one of the extras to splice into one of the relays I used because one wire wasn't there. You will see what I mean when you get to setting it up.
I will see if I can find the diagram. I think I saw a pic of those relays on here too. Where in SC are you??
YelloJeep is offline
post #140 of 244 Old 09-30-2010, 05:54 AM
YelloJeep
These are the relays. Maybe $1 each at the junkyard. Wait until LKQ has one of the 50% off days.. Go get the fan and everything.
post #141 of 244 Old 09-30-2010, 05:59 AM
JKDinSC
im in the charleston area of SC Goose Creek to be specific, but yeah if somebody could write me up a wiring diagram on how i wanted it to turn on and off as i stated above that would help alot because in my auto classes at school right now we're working with wiring relay circuits and stuff and if i had a diagram i think i could do this
JKDinSC is offline
post #142 of 244 Old 09-30-2010, 06:27 AM
YelloJeep
I will look and see if I can find the one I used. It is on this forum somewhere. If you look you should be able to find it or one like it. Oh, and I'm not a big electrical person and I was able to do it. The diagram I used had a three way switch and had "auto" (temp switch controlled), "high fan", and "off"(for water crossings.).
post #143 of 244 Old 03-05-2011, 01:21 PM
Jeremy302
Just trying to keep this thread going a little longer .
I was just wondering on a '99 WJ if the factory plug to the eFan would work at all with the Taurus 3.8 fan. (or any other fan for that matter assuming the plug was modified to plug into another fan) Is it's only function to turn on the fan when the A/C is on?
Is the only really good option to get a thermostat relay kit with A/C activation included? Would the A/C activation part of the kit just have to be tied back into the factory fan wiring/plug?
This vehicle is 99% street & highway driven. So I'm only curiously looking into this modification for a little fuel economy benefit. I would like it to work as much as possible like a factory electric fan setup so the fan only kicks on when needed. Especially while driving outside of city streets.
I this the main parts list I'll need basically to do this:
High CFM fan (2000cfm or better?)
Thermostat relay kit
Thanks,
Jeremy
Jeremy302 is offline
post #144 of 244 Old 03-05-2011, 02:14 PM
crosschecker
1995 XJ Cherokee
Thanks,
Jeremy
Sounds like you're looking at the same thing as I am, a stock setup but maybe a little fuel economy. The Taurus fan on high is 4500 cfm. There are lots of speed fan controllers out there that hook in to your A/C and are ignition wire triggered. That should take care of you. Also, make sure the fan is from a 3.8l Taurus to get the right fan.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #145 of 244 Old 03-05-2011, 03:00 PM
Jeremy302
To simplify the installation I was only thinking of wiring it up for one speed. Has the low speed been sufficient enough for everyone using the Taurus 3.8 fan? If it ever became an issue or if I was going to be doing any towing I would then see about adding another relay for the high speed. Is high speed very loud compared to low as the everyday speed setting?
post #146 of 244 Old 03-05-2011, 03:27 PM
crosschecker
1995 XJ Cherokee
You're talking the difference between hooking up one extra wire or not. What's the issue with that?
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
post #147 of 244 Old 03-05-2011, 04:24 PM
Jeremy302
Isn't there also a second, larger amp relay needed to run the second speed, plus a switch to toggle between the two?
post #148 of 244 Old 03-05-2011, 08:26 PM
crosschecker
1995 XJ Cherokee
If you get a controller that is set up to run the, it will have two relays, probably 30A each. When the fan is running and the switch is made to high speed, the fan is already running and doesn't need a big amp draw to bring it up to full speed.
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
post #149 of 244 Old 03-06-2011, 12:16 PM
Jeremy302
What is this controller you are referring to? I don't recall reading about anyone using one in the previous pages or any other sites regarding this fan conversion. Is this something similar to the Cadillac relays some people are picking from the junk yards?
I'm just trying to keep this as simple and clean as possible. If the low speed is all the engine really needs to keep it cool then the need for high is overkill. Plus that saves any unnecessary draw and wear on the alternator. If the conversion ends up being 6 one way half a dozen the other in regard to wiring for low only or wiring for low with option of high then I'll consider that route too. Let me know what you know about the controller you are talking about and maybe that will help clear things up. I'm not apposed to being safe rather than sorry.
post #150 of 244 Old 03-06-2011, 01:50 PM
crosschecker
1995 XJ Cherokee
2 speed fan controller
This is the fan controller I'm going to install once we get some decent weather. It has an A/C switch and can actually run two fans, also 2 speed fans. The controller is hooked into a switched ignition wire. The controller runs off the engine temp so it only runs the fan as needed. Straight forward, even comes with fuses and temp probe.
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
Ford Taurus E-fan? MeWJWifeZJ ZJ Grand Cherokee Forum 9 04-01-2009 10:58 AM
Taurus E-Fan Install gabrod72 ZJ Grand Cherokee Forum 5 11-25-2008 01:27 PM
finally installed my ford taurus fan MEinSoCal ZJ Grand Cherokee Forum 12 08-11-2008 06:13 PM
Ford Taurus fan swap Casper4x4 ZJ Grand Cherokee Forum 1 07-11-2008 07:49 PM
Ford Taurus 2 Speed Fan Swamp Boy ZJ Grand Cherokee Forum 11 01-13-2004 02:38 PM
