Ford Taurus fan swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ford Taurus fan swap
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 07-11-2008, 05:08 PM   #1
Casper4x4
Alright so I have read up on this swap and wanted to know a bit more info before i go in about doing this. A few questions i have are:
What exactly do i gain out of this?
As far as my stock fan, i do take it out and replace it with this?
And one of my main questions is as far as wires go, what do i need to have to install this in the heep.
If you have any other kind of input on this please lemme know.
Thanks,
Alonzo
Oh and I hit 1000 posts!!!!!
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline   Reply With Quote
Unread 07-11-2008, 07:49 PM   #2
zacjeff
i just did this a couple days ago.
first take out the old fan and shroud (4 bolts on fan and i think 2 bolts on top of shroud and 2 on bottom) and slip them out together
cut off all the old clips and mounting brackets off of taurus fan
this next part might sound confusing but once you see it it isnt, on the motot side of the radiator at the bottom theres 2 metal clips sticking up ( i put the fan in as far down as it would go resting on top of clips and marked it, then pull it back out and cut 2 slots in it)
then when the clips slide into slots i put a washer onto the head of a ziptie and poked it through the radiator and used another ziptie head/washer to hold it down
for wiring i mounted the relay to the left of the batery on the fender well wired it to the fan and spliced a switch to the blue wire with a grey tracer under the steering column so it'll only come on it the key is on the run position and i can turn it off with the switch
i know i made that sound confusing but it isnt, and if you need to know anything just ask
4.0 I6, 30" by 9.5" dueller at's, crager soft 8's, 2" BB, home made quick discos, K&N cold air intake, ford taurus e-fan
"I say if your kid knows peanuts will kill him and he insists on stealing someone's p-butter sandwich, that's just darwin in action."
zacjeff is offline   Reply With Quote
