-   -   Ford Taurus E-fan? (http://www.jeepforum.com/forum/f13/ford-taurus-e-fan-741890/)
MeWJWifeZJ 03-30-2009 09:04 AM
Ford Taurus E-fan?
What is so special about these that makes GC owners want to upgrade? There are a few for sale locally, so I am just wondering what the hype is versus the stock e-fans in our GC's
zaq123 03-30-2009 09:20 AM
you don't have e-fan in your ZJ unless it's 5.9
SaturnICL 03-30-2009 12:06 PM
I converted mine for... 1)to get rid of the clutch fan dragging on the motor. 2) the ability to turn off the fan during water crossings. 3) faster morning warm up. 4) Free up more room on the front of my motor for my York OBA :D
blackjack12982 03-30-2009 12:21 PM
Same here, I'm doing the e-fan conversion right now. All of the above, plus the fact that on high you could cool off a jet engine with that fan.
MeWJWifeZJ 04-01-2009 08:11 AM
Time to put one in the Wife's ZJ then. Is this also a common upgrade for the WJ?
EVIL ZJ 04-01-2009 10:14 AM
I considered the "Taurus"...
Went "Flex-a-lite"...
A club member even had 1 I could have FREE but the Flex-180 comes w/ALL hard-wear, wire, mounts & Adj. stat...& a warranty...
Flex-a-lite pulls 3300 cfm @ 12 amps...
Taurus pulls like 2400/2800 cfm @ near 80 amps & you have to fab all your own wiring & mounts...
Flex runs around 200' w/AC running in the desert ALL DAY...
My 2 cents...M...VP. S.P.O.R.A.
EMTimZJ 04-01-2009 10:25 AM
The Taurus fan does pull around 85 amps INITIALLY FOR START UP ONLY, then drops below 40 amps for continuous draw. This is for the "high" speed.
For low speed, the continuous draw is below 12 amps.
besthaticouldo 04-01-2009 10:28 AM
what flex a lite fan did you go with?
how did you all wire it up? to a switch inside or automatically off temp or what?
just curious, have to replace radiator soon and may end up going e-fan
oh also did you use a puller fan or pusher fan? im assuming puller...since its on the inside of the radiator...
let me know please, thanks!
EVIL ZJ 04-01-2009 10:58 AM
Flex-a-lite #180 - universal... (185 is for a 5.0 ford...)
Hot to battery...
runs/cycles till cool... (5-7 times after shut down when hot)
Stat. set to about 195...
Runs around 200/205 in the desert w/AC on...
& also hooked to + @ AC comp. power...
Plans to wire a kill switch for water crossings before "Monsoon Season"...
Link...
http://www.flex-a-lite.com/auto/html...c_x-treme.html
The time now is 12:56 PM.
