Quantcast Ford Taurus 2 Speed Fan - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ford Taurus 2 Speed Fan
Old 01-08-2004, 08:29 AM   #1
Swamp Boy
I installed this last weekend.. It is awesome..
Cost me $14 at a Boneyard... Its the best money I have ever spent on my ZJ.. The fan shroud fit right into the ZJ radiator and cools like a champ.. Unbelievable...
Also there is a very noticable difference in power...
And to top it all off its much quieter than the clutch fan...
Just wanted to post up and let you guys know about this..
Just another soccer moms Grocery getter....
[Url]http://www.jeepforum.com/gallery/files//8/5/6/5/hatt034.jpg[/url]
Swamp Boy is offline   Reply With Quote
Old 01-08-2004, 01:50 PM   #2
Harald
Sounds great, the on/off thermostatic switch, where do you place it? And what's the year of the Taurus?
Harald is offline   Reply With Quote
Old 01-08-2004, 04:43 PM   #3
Meerkat
Yes, we need more details!
Spell it out for me, I'm kinda slow...
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote
Old 01-08-2004, 06:28 PM   #4
Swamp Boy
I have not installed the thermostatic switch since its winter..
(Ill do that when its warmer..) I just watch the temp gauge and
if it gets warm .. I turn it on low..
I will mount the sesor to the side of the radiator inside the shroud.. It will be very simple..I am about to go take pictures of it so I will have them up in a few...
The 2 speed fan is in any boneyard taurus with a 3.8 litre engine..
Also some lincolns with the 3.8 ( could possible be in others..)
The easiest way to tell is to look at the wires..
A 2 speed fan will have 3 wires.. where a sigle speed will only have 2..
Pics will be up in a minute..
Old 01-08-2004, 06:51 PM   #5
Swamp Boy
OK.... here we go.. Before I get any crap... I know the pictures suck.. But its cold and dark outside.. And its raining.. I will try to get better pics tommorow but these should hold you over till then..
Here are my relays...
Here is a picture of the fan.. You can see how well it fits the radiator and the small brackets I had to make to hold it up..
I will try very hard tommorow to get a picture where you can see both sides of the radiator.. To show exactly how well it fits..
The metal strips are just aluminum strap from Home depot..
I drilled two holes in them ONe for the stock fan shroud mount (top) and one for the small screw and nut I put thru the edge of the new fan shroud..
The fan has small platic clip thingys that clip in the side of the radiator like the stock shroud did..
Here is a picture of where my switches are ...
The bottom is for my OBA the second is fan low the top is fan HI..
I know I could have used a 3 pos . switch but I thought 2 switches would be cooler...
Hope that will be enough to tide you guys over till it quites raining..
Carl
Old 01-08-2004, 09:46 PM   #6
Meerkat
Thanks, Carl!
Great pics, and a great cheap-o mod!
Warren
Old 01-08-2004, 11:20 PM   #7
Swamp Boy
IT will definatly be the best money you ever spent.. .
It cools better and drags much less on your engine..
If you need any other info let me know..
Old 01-10-2004, 06:16 PM   #8
Harald
Thanks for the pic.s and prompte reply, will follow your example. My other car, by the way, is a 1993 Taurus 3,8L. Not quite ready for the bone yard yet.
Old 01-10-2004, 07:19 PM   #9
Swamp Boy
Yeah.. There are enough of them in the boneyard already..
Keep yours rolling..
Good luck .. and post pics ...
Old 01-12-2004, 03:39 PM   #10
ZJGuido
Junior Member
awesome mod.
It's true, you can really feel the fan drain power when it engages, thats y i want to get rid of it.
I was wondering if this would also work for a 4.0? If so, how would i remove the clutch fan? Also, did u get the thermostats with the fan, or did u buy them separate?
Thanx for ur help.
1998 Platinum ZJ 5.9 Limited [B][COLOR=DarkRed][I]71K miles[/I][/COLOR][/B]
[URL=http://members.cardomain.com/zjguido]My ZJ 5.9 Limited[/URL]
1997 Stone White ZJ Limited w/4.0L [B][COLOR=DarkRed][I]120K miles[/I][/COLOR] [/B]
[URL=http://hometown.aol.com/stangabang/]My ZJ Limited[/URL]
[U]Previous Jeeps:[/U]
1995 Green ZJ Laredo w/4.0L [B][I][COLOR=DarkRed]95K miles[/COLOR][/I][/B] [B][COLOR=Blue]-RECKED-[/COLOR][/B]
1989 White XJ Laredo w/4.0L [B][COLOR=DarkRed][I]86K miles[/I][/COLOR][/B] [COLOR=Blue][B]-SOLD-[/B][/COLOR]
[B][COLOR=Green][I]JEEP[/I][/COLOR] ROCKS!!!!!![/B]
ZJGuido is offline   Reply With Quote
Old 01-12-2004, 09:38 PM   #11
Swamp Boy
Looked at 4.0 today. looks like it will work. Your fan and clutch will unbolt w/ 4 screws . Thermostats and switch availble at autozone near elec' fans, $24.00.
Godd Luck
Old 01-13-2004, 03:38 PM   #12
ZJGuido
Junior Member
Excellent!! Greatly appreciate you helpin me out. I'll get to work on it as soon as i get a chance. Can't wait! I'll keep u posted and let u know how it worked out.
Thanx again!
Glock Forum
