Foglight change help - JeepForum.com
post #1 of 2 Old 01-08-2003, 03:14 PM Thread Starter
Beachead19
Beachead19's Avatar
I know this should be an easy thing to do, but after I unscrew the access panel under the bulb there is a sort of rubber skin inside the access panel protecting the housing. It doesn't want to peel off and I don't know if i want to rip it off or not. Any help?
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #2 of 2 Old 01-11-2003, 02:35 PM
brad335
I could be wrong, but I do believe this is just a gasket to keep water out of the bulb. I would take great caution in removing it, as water on a hot bulb would easliy burn out the light.
~~Brad~~
brad335 is offline
'05 GC Foglight Switch Help Jeep_Warrior WK Grand Cherokee & XK Commander Forum 3 10-14-2009 03:32 PM
foglight? ligcmp WK Grand Cherokee & XK Commander Forum 8 09-15-2009 07:26 AM
Foglight Install Help ! sontog ZJ Grand Cherokee Forum 1 06-10-2009 08:15 AM
foglight S10Eater ZJ Grand Cherokee Forum 4 06-22-2006 06:03 PM
Foglight Lens kensue49 ZJ Grand Cherokee Forum 1 04-11-2005 07:45 PM
