Quantcast fog lamps. which ones are right, 9055, 9040, 9145 or 9005? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > fog lamps. which ones are right, 9055, 9040, 9145 or 9005?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 01-01-2010, 12:57 AM   #1
ronsaun
2003 WJ
03wj which fog lights are right. i have been researching and am getting conflicting info!!! are they 9055, 9040, 9145 or 9005? this is my last lamp type question. thanks, ron
ronsaun is offline   Reply With Quote
Old 01-01-2010, 01:14 AM   #2
JesseOR
Pull one. Then you'll know. Or ask a parts store
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline   Reply With Quote
Old 01-01-2010, 09:45 AM   #3
ronsaun
2003 WJ
i think i would prefer to lay on my back in the snow only ONCE today. thank you very much! do you have a helpful answer?
Old 01-01-2010, 09:46 AM   #4
ronsaun
2003 WJ
Old 01-01-2010, 11:07 AM   #5
JesseOR
I wasn't giving you a stupid answer. I was telling you what I would do. Its the easiest way. Takes a couple minutes.
Do you have an owners manual? Its in there too.
There are plenty of ways to get the answer then be lazy and ask on here.
-Jesse-
GO DUCKS!
Old 01-01-2010, 12:40 PM   #6
straty1987
Pie>Pie>Cake
9055 for 99-02
9040 for 2003
9145 for 2004
but you can fit a 9005 in all of them and it will be better since it is high beam bulb.
and then if you have the time and space adjust it if you want, stock they are pointed lower so if you move them up a bit make a big differences
Jeep Grand Cherokee WJ - Auto headlamps and headlamp alignment
straty1987 is offline   Reply With Quote
Old 01-01-2010, 03:45 PM   #7
ronsaun
2003 WJ
Originally Posted by straty1987 View Post
9055 for 99-02
9040 for 2003
9145 for 2004
thank you fine sir! that is exactly what i was looking for. you must have recognized by my original post that i was confused by the fact that i have seen numerous posts on here in regards to the 9005 being used instead of the original replacement. now i know why. thanks again, ron
Old 01-01-2010, 03:53 PM   #8
iluvtruenos
You can easily fit a 9005 bulb in there by sliding one of the tabs in first, rotate, then slide the remaining two in.
It clips right up.
My Jeep is a chick magnet with reverse polarity.
Rampant Pack of Retards group president.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline   Reply With Quote
Old 01-01-2010, 06:33 PM   #9
straty1987
Pie>Pie>Cake
glade it helps. i was confused when i use to here 9005 in fogs too since it i thought it was the other ones
if you don't mind the few extra bucks i would say put the 9005 in there since are brighter
Old 01-01-2010, 07:09 PM   #10
myjeeplovesmud
They Call Me "Mud"
myjeeplovesmud's Avatar
i run 9005's in my fogs, they work great, just aim them down a hair, otherwise they are blinding
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
MY BUILD THREAD
BAD TO THE BONE ZONE
November 2010 GCOTM
myjeeplovesmud is offline   Reply With Quote
Old 01-01-2010, 09:59 PM   #11
straty1987
Pie>Pie>Cake
that's odd most people with a non lifted jeep say they turn them up. you do have it lifted a bit.
but did you follow the alignment proceeds or point them to were you like them or though there best output?
Old 01-06-2010, 09:37 AM   #12
crash91
Just a question, where could a guy find this alignment process? have done a couple searches and havent really found anything.
Also if you are looking for what bulbs are in your vehicle check this link out...hasnt let me done yet.
Sylvania Light Replacement Guide
crash91 is offline   Reply With Quote
Old 01-06-2010, 07:41 PM   #13
straty1987
Pie>Pie>Cake
i posed it above for the WJ 99-04 jeep , here you go Jeep Grand Cherokee WJ - Auto headlamps and headlamp alignment
looks like your new so check out WJ Jeeps.com - Main Menu all info in the 99-04 jeep GC
Glock Forum
