Foamy power steering fluid??? - JeepForum.com
post #1 of 13 Old 12-23-2007, 09:38 PM Thread Starter
FortCollinsZJ
I started my jeep, turned the wheel, it made a sickly groan, I opened the power steering res. and it was foamed up... what the hell is this!!!???
On a side note, it has been leaking very slowly lately from the pump.
FortCollinsZJ is offline
post #2 of 13 Old 12-23-2007, 10:12 PM
colinzj
2006 WK
It'll get foamy when there's air in the system, as you're likely to have with a leak or a low fluid level.
Let it settle back down to fluid, check the level, and top it off. If you're lucky, that'll get you running actual liquid again for a while. If not, start by fixing the leak and move on from there. The steering gear doesn't like running on foam, and those puppies ain't cheap.
colinzj is offline
post #3 of 13 Old 12-23-2007, 10:17 PM
Virmagicus
Virmagicus's Avatar
x 2 You are sucking air.
Jeff
Virmagicus is offline
post #4 of 13 Old 12-23-2007, 10:37 PM Thread Starter
FortCollinsZJ
Thats what I figgured. DARN. Well it is leaky, so that may be where the air is coming in. GREAT. Any idea how much a new "puppy" (pump) would cost??
post #5 of 13 Old 12-23-2007, 10:44 PM
00RedWJ
2006 WK
It could be leaking from a hose connection to the pump. Once it runs low on fluid it will foam up as air gets sucked in
00RedWJ is offline
post #6 of 13 Old 12-24-2007, 02:00 AM
Ds4x4
Ds4x4's Avatar
just top it off and then turn lock to lock a few times and see if it helps.. check the junkyard if you want for a low mile pump or hit autozone/napa or something
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline
post #7 of 13 Old 12-24-2007, 12:53 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Napa pumps aren't that great - I'm wishing I had gone with a mopar pump, whether it was from a yard or a dealership. Pricey though - about 300 bones.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #8 of 13 Old 12-24-2007, 01:58 PM
alivenkickin28
yeah mine is doing this only when its cold outside...so im afraid its gonna go soon...
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #9 of 13 Old 12-24-2007, 10:43 PM Thread Starter
FortCollinsZJ
Well I checked it... it was damn low... like way too low. Its good and filled now... maybe that will help I havn't ran it yet though.
post #10 of 13 Old 12-24-2007, 11:08 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Bleed it before you do Neil - Stop to stop, don't quit at either end for too long or else you could hurt the pump. Check the level frequently.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #11 of 13 Old 12-25-2007, 11:00 AM
Redbob
Hoses can leak too; either the pressure or the return hose can leak.
I'd recommend if you're replacing the pump to save yourself some headaches down the road and replace both hoses at the same time.
Redbob is offline
post #12 of 13 Old 12-25-2007, 08:13 PM
kentman
kentman's Avatar
2006 XK Commander
Mine died at 216K miles. That is pretty good if you ask me.
My failure was a complete mess at a completely bad time, on vacation in the middle of downtown DC during the Cherry Blossom Festival with four adults and a child in the Jeep. They all took the train home while I got AAA to truck me back to my brother's house. I did the swap that night. It could have been worse (freeway halfway between destinations).
If you are losing fluid and groaning, I would swap the pump. I had fluid spewed all over the engine bay, and I am still finding individual bearings in the bay.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
post #13 of 13 Old 12-20-2009, 09:18 AM
weedey224
same thing happened too me.so i flushed my system with powerstearing fluid first.(figuring that will fix it) same thing happened again. tell i found out that power stearing pumps should be running ATF fluid on them. it puts less stress on ur system when it is cold out side
weedey224 is offline
Power steering fluid to use? kontrast ZJ Grand Cherokee Forum 2 12-27-2009 10:18 PM
What power steering fluid can I use? ct-snoman ZJ Grand Cherokee Forum 12 04-28-2009 12:37 PM
foamy tranny fluid ctwistedpair ZJ Grand Cherokee Forum 10 12-08-2007 11:42 PM
Power Steering Fluid shashank ZJ Grand Cherokee Forum 10 10-26-2007 06:46 AM
Power steering fluid miteus ZJ Grand Cherokee Forum 5 10-25-2006 05:15 PM
