FM Radio Reception / Blower Motor
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
'96 Jeep Grand Cherokee Laredo with 126,xxx miles
AM/FM Cassette Manual HVAC I have two unrelated issues (one is 6 months old, the other happened today) I'm trying to resolve..... 1st.... My radio (without warning) stopped receiving FM radio stations on the way home from work today. The AM band still works perfect, very clear reception. Since the AM is perfect and the FM death was sudden, I'm guessing the radio is the culprit vs something like a broken/loose antenna cable. I'll pull the radio tomorrow and make sure the coax is connected but I'm not holding my breath. Comments? 2nd... About 6 months ago, the "High" speed setting for the HVAC blower motor began working intermitently and then stopped working completely. - The Low and both Medium speeds work perfectly - I got a hold of a spare HVAC dash unit and there was no change - Swapped in a spare blower motor to no avail From looking at the schematic in the Service Manual, it appears the voltage bypasses the resistor for "High" speed, so that eliminates it from the equation. Any idea where to look for the ground? The Factory Service Manual wasn't real clear on connector locations. Thanks
#2 |
I had the same problem with mine.
It was the connector to the Resistor Module. I'm not sure if you have the same one as my 01 Jeep Cherokee. Last edited by Jeep01; 08-16-2006 at 05:43 PM.. |
#3 | |
I'll check the pins for corrosion and then chase the wires back to the switch. I hate electrical problems ![]() |
#4 |
resistor pack is what you need
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#5 | |
#6 |
From the FSM
BLOWER MOTOR RESISTOR BLOCK DESCRIPTION Models with the standard manual temperature control system have a blower motor resistor. The blower motor resistor is mounted to the bottom of the HVAC housing, under the instrument panel and just inboard of the blower motor. It can be accessed for service without removing any other components. OPERATION The resistor has multiple resistor wires, each of which will reduce the current flow to the blower motor to change the blower motor speed by changing the resistance in the blower motor ground path. The blower motor switch directs the ground path through the correct resistor wire to obtain the selected speed. With the blower motor switch in the lowest speed position, the ground path for the motor is applied through all of the resistor wires. Each higher speed selected with the blower motor switch applies the blower motor ground path through fewer of the resistor wires, increasing the blower motor speed. When the blower motor switch is in the highest speed position, the blower motor resistor is bypassed and the blower motor receives a direct path to ground. The blower motor resistor cannot be repaired and, if faulty or damaged, it must be replaced. DIAGNOSIS AND TESTING - BLOWER MOTOR RESISTOR BLOCK For circuit descriptions and diagrams, refer to the appropriate wiring information. WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN AN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY. (1) Disconnect and isolate the battery negative cable. (2) Unplug the wire harness connector from the blower motor resistor. (3) Check for continuity between each of the blower motor switch input terminals of the resistor and the resistor output terminal. In each case there should be continuity. If OK, repair the wire harness circuits between the blower motor switch and the blower motor resistor or blower motor as required. If not OK, replace the faulty blower motor resistor. Ryan
2004 Grand Cherokee Limited Brilliant Black Crystal Pearl Navigation System 4.0L K&N Filter Chrome Tow Hooks Bilstiens Mobil 1 |
#7 |
I'm a little confused on exactly where the resistor is located. So is it inside the cabin on the passenger side? Or driver's side? Anybody have any pics/diagrams?
Thanks! |
#8 |
Blower Motor Resistor Removal
REMOVAL (1) Disconnect and isolate the battery negative cable. (2) Depress locking tab and unplug the wire harness connector from the blower motor resistor. (3) Depress locking tab and unplug the resistor connector from the blower motor. (4) Remove the 2 screws that secure the blower motor resistor to the HVAC housing. (5) Remove the blower motor resistor from the HVAC housing (Fig. 16). ![]() ps. it is in the passenger footwell. The view in the pic is upside from what you will see when you look under the glovebox. Ryan
#9 |
Thank you so much!!!
#10 |
Thanks for posting Ryan. I'm in the process of moving to Seattle, WA from St. Louis, MO and all of my manuals and such are on a moving truck in transit.
As mentioned in the write-up, the resistor is bypassed when the switch is set to high, so it looks like I have a wiring issue to chase once we're moved in ![]() |
#11 | |
#12 | |
It's fixed!
We're having a house built which means we're stuffed in an apartment, most of my tools are in storage, and of course no garage, all of which adds to the challenge I have a radio on the way with a CD player to replace the current one that's lost its FM function. Hope to have that later this week or early next week. Thanks to all that took the time to reply |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
