To flush or not to flush, that is the question. - JeepForum.com
post #1 of 32 Old 02-22-2008, 03:42 PM Thread Starter
JBN311
1. I'm changing the trans fluid and I have been searching the forum to find out if a trans flush is needed, I can't seem to find a clear cut answer.
It just passed 60,000.
2. Also, the FSM looks kind of complicated when looking at the diagrams. When I break into it, will it be more obvious where the filter seats etc???
I have never dealt with the trans. Can I just get a filter change kit or something?
Thanks.
-Jesse
2004 WJ Laredo V8, NP242 swapped in, front Dana 30 w/ Vari-Lok, Aussie Locked 44a, BB, 30" BFG A/T's, Tow hooks, Rear Hitch, CB, Better than stock radio/MP3 player.
JBN311 is offline
post #2 of 32 Old 02-22-2008, 04:11 PM
Windowsrookie
Just change the fluid in the pan. I'm not a fan of flushing.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #3 of 32 Old 02-22-2008, 04:29 PM Thread Starter
JBN311
What about the filter?
-Jesse
JBN311 is offline
post #4 of 32 Old 02-22-2008, 04:33 PM
CLASH
CLASH's Avatar
I would use a quality filter and just refill the pan.
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline
post #5 of 32 Old 02-22-2008, 04:35 PM
CMARJEEP
CMARJEEP's Avatar
60k is one of the big maintenance schedules. it includes changing almost everything, including the tranny. i agree though just to refill the pan, change the filter, then get new gaskets. check out wjjeeps.com for what you should be changing and doing at 60k...
CMARJEEP is offline
post #6 of 32 Old 02-22-2008, 05:01 PM
manofmany
Drain and Refill ONLY
Do not let anyone convince you that flushing your transmission is good. It's not.
1998 Cherokee 4.0L
1999 Grand Cherokee Limited 4.7L
manofmany is offline
post #7 of 32 Old 02-22-2008, 05:04 PM
sandman
well if theres a turd flush, aka if the fluid looks like crap flush it,
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 32 Old 02-22-2008, 06:01 PM
CrazyWalnut13
Correct
"If it's brown, flush it down; if it's yellow, leave it mellow"
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #9 of 32 Old 02-22-2008, 06:10 PM
RJV
why do you think that? If the fluid is dark that is the only way to get all of the fluid out and replace it with new fluid. the only time i would steer away from a flush is if it is a high mileage vehicle that has never been maintained.
RJV is offline
post #10 of 32 Old 02-22-2008, 06:15 PM
Chief Slacker
This info is incorrect for a vehicle w/ only 60k on it.
EXACTLY Correct!!!!
By simply dropping the pan......you are not getting the fluid out of the lines,converter,cooler,etc. A vehicle with only 60,000 miles on it should most definitely get a complete flush!
Chief Slacker is offline
post #11 of 32 Old 02-22-2008, 06:22 PM
Windowsrookie
Do what you want, but I would never flush a transmission. If you want to get all of the fluid out disconnect one of the hoses and let the transmission pump the fluid out itself.
1987 Wrangler 4.2L
post #12 of 32 Old 02-22-2008, 06:23 PM
Turbonut
Chrysler fluid will turn dark over the time and is not an indication of a problem, it's normal. The fluid is actually 100,000 mile fluid under normal driving condititons.
Change both filters, the flat and spin on, and make certain it's the updated design. The flat filter needs to have the seal pryed from the trans body , then the new one installed into the body before installing the filter. I put a wooden hammer handle against the seal, then hit that hammer head to drive the seal in.
As stated above, take a look a wjjeeps.com.
Turbonut is offline
post #13 of 32 Old 02-22-2008, 06:38 PM
CLASH
CLASH's Avatar
on zj 42re they only have 1 filter right?
CLASH is offline
post #14 of 32 Old 02-23-2008, 06:12 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Yes there is only one filter and you need a T25 wrench to remove the three filter bolts.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #15 of 32 Old 02-23-2008, 06:15 AM
greasefingers
1994 ZJ
To flush a perfectly fine operating tranz is only asking for trouble. Remove the pan and replace the filter and then fill thru the tranz dip stick. If you are worried about replacing most of the fluid, then replace the fluid twice over two weekends.
Cheers Steve
Tranny-To flush or not to flush? craddock01 ZJ Grand Cherokee Forum 5 05-07-2009 07:58 PM
Tranny Flush Question UofOJeeper ZJ Grand Cherokee Forum 3 03-31-2007 10:13 PM
Brake fluid flush and fuel injection flush ArloGuthroJeep ZJ Grand Cherokee Forum 8 05-25-2005 07:46 AM
Motor Flush question... JohnnyCash ZJ Grand Cherokee Forum 4 08-29-2004 07:42 AM
to flush or not to flush? shel3702 ZJ Grand Cherokee Forum 2 07-10-2004 04:14 PM
