fluid coming from the rear diff? - JeepForum.com
post #1 of 3 Old 07-20-2009, 05:03 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
My rear diff seems a little wet is this the diff leaking or something else? Would it just be a leaking gasket? If so how hard is it to replace and what kind of gear oil would you use in it?
Mudzilla6661 is offline
post #2 of 3 Old 07-20-2009, 06:08 AM
Turbonut
Is it leaking at the driveshaft side-pinion seal, leaking at the cover side, bad gasket or RTV seal.
80W-90 unless you tow or want to spend the money for synthetic 75W-140.
Turbonut is offline
post #3 of 3 Old 07-20-2009, 09:49 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
I'm not sure where it is leaking from. It looks wet on the cover side or underneath I believe. I will double check today.
Whining/Roaring Noise coming from rear driveshaft/diff. asu4x4TA ZJ Grand Cherokee Forum 5 02-21-2011 07:27 PM
rear diff fluid limitedman ZJ Grand Cherokee Forum 4 11-30-2009 08:11 PM
clickin noise while moving coming from the rear diff under jeep could use some help CrazyDrivinJoe ZJ Grand Cherokee Forum 0 01-10-2009 01:15 PM
Rear Diff. Fluid Change 2002GC ZJ Grand Cherokee Forum 22 02-29-2008 08:09 PM
strange liquid coming from behind rear diff. SouthernboyWJ ZJ Grand Cherokee Forum 7 01-18-2007 07:41 AM
