Fluid change on 42re-filter gets replaced? - JeepForum.com
post #1 of 9 Old 09-23-2009, 11:26 PM Thread Starter
my2monkeys
1989 XJ Cherokee
Do you guys drop the pan and filter during routing service? This is my wifes 95 zj, it doesn't have a drain plug like my 89 xj aw4. So I usually just suck it out thru dipstick tube. But I'm thinking I probably should drop pan and inspect,it's got 160,000mi on it. And what about band adjustment? Any info would help.
my2monkeys is offline
post #2 of 9 Old 09-23-2009, 11:54 PM
the88thpianoman
2003 WJ
AFAIK, a band adjustment is only necessary if you are having symptoms, slipping, etc. If it is shifting fine, the bands are fine. If you're going to drop the pan and replace the filter (which never hurts), it'll be quite messy the first time, but not after that if you install a drain plug kit. I highly recommend doing this.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 9 Old 09-24-2009, 12:05 AM
sandman
yea drop the pan, check the magnet for metal pieces and change the filter.
1993 Jeep ZJ. 4.0
sandman is offline
post #4 of 9 Old 09-24-2009, 05:36 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I would recommend draining and replace the ATF & filter. If you are concerned about replacing even more fluid, since draining only removes about half of the volume, then I would replace the ATF twice over a couple a days. This will replace the fluid by dilution. Not the best way but not too bad either. Removing the tranny pan also reveals how much metal has worn away and you get to clean the magnet, and you can replace the filter.
A T25 Torx Hex wrench/bit is needed for the filter removal (at least for ZJs)
If I am using a cork or rubber gasket I do not RTV on it because I install the bolts with a torque wrench (150 in-lbs) But many people use a small bead on the pan side only. Currently I am using a ridge type rubber encapsulate metal gasket. This can be removed and reused a couple times, so never use RTV on this type.
WalMart sells Mopar +4 AFT for $ 4.42/qt
The tranz filter at the dealer is about $ 6
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 9 Old 09-24-2009, 07:10 AM
gomes512
1994 ZJ
I'd change the filter also and continue doing fluid changes the way you have done if you don't want to install a plug.
New fliter and clean the mags and button it up for another 160K
gomes512 is offline
post #6 of 9 Old 09-24-2009, 07:23 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Adjust the bands at every service. They're a wear part.
ratmonkey is offline
post #7 of 9 Old 09-24-2009, 12:32 PM
4Slow9erHybrid
You seem to know about these trannys. The 97 and 98 FSM tells me to back out the adjuster screw for the front band 3-5/8 turns for 42RE and 2-1/4 turns for 44RE. The 96 FSM on the other hand says 2-7/8 turns for both 42 and 44RE.
The numbers for the rear band are 4 turns (97, 98) and 2 turns (96) for both 42/44RE.
Has Chrysler modified these trannies in 97 and hence the different adjustments? Or they simply revised the adjustment numbers in 97?
I adjusted mine yesterday to 3-5/8 turns (front). Haven't tested it yet as my Jeep is undergoing a major overhaul (still in pieces).
Thanks
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #8 of 9 Old 09-25-2009, 02:19 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
There are some modified numbers out there from a few tranny rebuilders that allow for better shifting timings. But following the fsm for each year is correct.
Chrysler changed valve bodies and thus shift parameters nearly every year in these units.
post #9 of 9 Old 09-25-2009, 07:29 AM
4Slow9erHybrid
Thanks for the info.
42re fluid change hints oujea ZJ Grand Cherokee Forum 5 12-19-2009 05:31 AM
Leaking tranny on 42RE after filter change loganbent ZJ Grand Cherokee Forum 7 08-13-2009 09:05 PM
how much fluid for tranny filter change? npray ZJ Grand Cherokee Forum 7 07-21-2009 11:03 PM
Code P1762 will a fluid change help? (42RE) nitecop ZJ Grand Cherokee Forum 3 06-14-2007 07:36 PM
42RE Mopar Low pressure fluid flush/filter change ok? CTCSTrela ZJ Grand Cherokee Forum 19 03-02-2007 02:34 PM
