flipping a class II drop hitch - JeepForum.com
post #1 of 9 Old 06-13-2011, 08:50 PM Thread Starter
tapenick
This may be a dumb question - but I tried to flip the drop hitch (to make it a rise hitch) on my 98 but it hits the bumper. Anyone know if there are hitches that curve or stick out far enough to resolve this issue?
Shopped around a little but just wanted to bounce it off of this forum to leverage any experience you guys already have.
Thanks!
Tom
tapenick is offline
post #2 of 9 Old 06-13-2011, 09:25 PM
jayeepee
instead of the drop one.. did you try the normal one with no drop? any parts store should let you at least try it out in the parking lot before you buy it...
jayeepee is offline
post #3 of 9 Old 06-13-2011, 10:15 PM
Midtown
I've got two or three and none hit flipped. They are just regular hitches.
Midtown is offline
post #4 of 9 Old 06-13-2011, 11:32 PM
jayeepee
more or less you need the upward height then..
jayeepee is offline
post #5 of 9 Old 06-13-2011, 11:38 PM
jayeepee
the way the class 2 hitch is, is that they are short shanked due to the weight capacity so you may have to take a smaller drop one and turn it to see if it still hits. I know from experience the class 3 has the longer reciever because i bought one! i've never seen a longer class 2.
good luck.
jayeepee is offline
post #6 of 9 Old 07-16-2011, 08:52 AM Thread Starter
tapenick
Thanks for the info guys. Check this out.. just looks dangerous to me!!
http://www.uhaul.com/MovingSupplies/...apters?mid=313
Tom
tapenick is offline
post #7 of 9 Old 07-16-2011, 10:15 AM
Dodgeram1989
1976 FSJ Cherokee
Not for towing use. For bike and accessory use only.
Says that right on the page
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #8 of 9 Old 07-16-2011, 10:34 AM
Corrupt
tapenick posted the wrong item. Here is the correct item.
http://www.drawtite.com/read.html
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #9 of 9 Old 07-16-2011, 10:41 AM
Dodgeram1989
1976 FSJ Cherokee
Same issue, good for bike racks and ect. But not for trailers
These Adapters are helpful when accessories such as a bike rack, or cargo carrier have a different size receiver than your trailer hitch.
Extensions help when you need to put more space between your tow vehicle and your accessory
97 ZJ - Stock again
Ball Mount Trailer Hitch Drop Help MudPit ZJ Grand Cherokee Forum 15 05-25-2010 02:00 PM
flipping the key and ignition... skiebuster ZJ Grand Cherokee Forum 4 08-18-2009 09:27 PM
flipping axles MTXZJ1 ZJ Grand Cherokee Forum 13 01-12-2009 08:11 AM
Class 3 hitch OK for recovery? chekk ZJ Grand Cherokee Forum 25 12-25-2008 09:23 AM
Best place to get a Class III hitch for a WJ? Air Dog ZJ Grand Cherokee Forum 4 06-11-2008 10:13 PM
