Flexplate to flywheel problems, please help!! - JeepForum.com
post #1 of 5 Old 05-13-2008, 12:14 PM Thread Starter
t_guenther
I have a 95 grand with a 5.2L and the engine was bad so i got a 5.2L out of a 98 grand. I have all of my sensors transfered over, but i didn't transfer the flexplate because i thought they were the same. Now i have the engine placed into the jeep, and i can only get 3 of the 4 bolts through the flexplate into the torque converter. The 4th is near a 1/4 of an inch off, maybe just a little less. Are the flexplates different or am i doing something wrong. I just don't want to pull the engine out again.
Michigan Tech. Univ. - MET, Senior
--95 Grand Cherokee 5.2L V8--
Front/Rear Adj. Track Bar, 249 to 231 Swap, Tie rod conversion,
Hella 500's, Flowmaster 50 Series, Aussie Locker in the Rear,
31x10.5 BFG All-Terrains on 15x8 Pro Comp 97 Crawlers, 3" Lift
t_guenther is offline
post #2 of 5 Old 05-13-2008, 12:25 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
they are proably diffferent, as they are different transmissions.
Transmissions
545RFE 5 spd. automatic transmission used in the 2001 - Current Model Jeep Grand Cherokee 4.7L engines
45RFE: 4 spd. automatic transmission used in 1999 - 2000 Jeep Grand Cherokees with 4.7L engines.
46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines.
44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines.
42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines
AX-15 5 spd. manual transmission used in 1993 - 94 Jeep Grand Cherokees with 4.0L engines.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 5 Old 05-13-2008, 12:28 PM
anticrombie
anticrombie's Avatar
Yeah, in 96+ they're at 90*, the other years there is on at like 88* to help align it.
Charlie
anticrombie is offline
post #4 of 5 Old 05-13-2008, 02:31 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Hmm, let me try this again.
You are going to need an asymetrical internal (zero) -balance flexplate from a 93-95 or a symmetrical torque converter from a 96-98. Either way the trans will have to come away from the motor.
You can hog out that one hole in the flexplate with a Dremel and force a match to the converter hole. You may end up with a nasty imbalance which you would notice right away.
HighLonesome is offline
post #5 of 5 Old 05-13-2008, 02:37 PM
CrazyDrivinJoe
1994 ZJ
i had the same thing happen to me and i just left it out until i brought it to s ahop because i did something else wrong and they put in the bolt
94 ZJ I6 Second 4.0 as of 226k Aftermarket Intake, Flowmaster 40 series, Rear Discs
05 Kawasaki Ninja ZX-6R 636 just ridiculously fast
96 Nissan Altima 5 speed stock and probably keepin it that way aka the beater or commuter car who wouldnt buy it for a grand with how gas is
CrazyDrivinJoe is offline
95' zj 4.0L, is a 96' zj 4.0L flywheel different? red88MJ ZJ Grand Cherokee Forum 4 09-04-2012 08:45 AM
I think I bent my flywheel...and it may have led to CPS problems fitz73chrgr ZJ Grand Cherokee Forum 1 12-29-2009 07:12 PM
Flexplate noise louder when cold elewis12345 ZJ Grand Cherokee Forum 2 10-14-2009 06:06 PM
Has anyone ever had a cracked flywheel? guy.griffin ZJ Grand Cherokee Forum 1 03-31-2007 09:11 PM
pulse ring/ flexplate connundrum wibblequikit ZJ Grand Cherokee Forum 12 03-04-2007 10:55 PM
