Flat Towing with Long Arms - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Flat Towing with Long Arms
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Boss is away but Erin is here to STAY with a F.Y.S. SaFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-19-2015, 09:59 AM   #1
somebody5788
1994 ZJ
So I'm planning on finishing up some loose ends on my Jeep and heading to the Badlands. It's about 4 hours from me. What I can't decide is whether I would be better off driving it there or flat towing it behind my Titan. The Jeep has a 4.5" Rubicon Express springs, Rough Country X-flex Long Arms, Iron Rock Off Road Double Sheer track bar, Bilstein 5100's, but stock steering components.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 11:42 AM   #2
kg6mov
Hears the voices
kg6mov's Avatar
As long as you have good caster you should be fine. The important thing is that the vehicle can track straight behind the tow vehicle and not try to steer the back end of the truck.
I'd be more concerned about getting it home. If you do damage to your steering or front end you may end up with a vehicle that is driveable, but not flat towable.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 03:25 PM   #3
somebody5788
1994 ZJ
I'm surprised someone actually mentioned caster, I was worried specifically about that (I am certified by John Bean for alignments) In order to get my driveshaft angle right I am at 0* caster, I have it so that it is tracking relatively good but I was concerned how that would react to flat towing.
Unread 05-19-2015, 03:41 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, I wouldn't feel comfortable with those numbers.
Maybe rent a dolly and disco the rear shaft? Or just rent a full trailer.
Unread 05-19-2015, 05:49 PM   #5
Taz360ZJ
i'd trailer it. what if you break a rear axle shaft or smoke a rear axle or carrier bearing? the JF guys convinced me that a car trailer would be better for towing my '93 home from texas, little hairy with a long armed ZJ but it did it and I didn't have to worry about stopping the dead ZJ too much or blowing a tire.
Slate 5.9 Limited 8"/ARB/IRO/KOR/OME/231
White 5.9 Limited stock/231/30's
'93 ZJ SE 5.9 clone
Taz360ZJ is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 06:01 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, brakes alone makes it worth it to get a trailer.
Unread 05-19-2015, 07:00 PM   #7
somebody5788
1994 ZJ
Eh, I have the tow package but no brake controller... It's got all the wires for it and even a nice little cut out in the dash for it just need to get one..
I have a flat bed tow truck but I don't think I'm comfortable strapping a 4500 lb lifted Jeep onto the back of an 87 F-350.
Unread 05-19-2015, 08:14 PM   #8
kg6mov
Hears the voices
kg6mov's Avatar
Surge brakes are better than no brakes.
