Flasher location for a '94 ZJ - JeepForum.com
post #1 of 5 Old 07-29-2012, 12:10 PM Thread Starter
Puv
1994 ZJ
So, my blinkers and emergency flashers just quit working. After some looking around I found the location for the flasher. It is under the glove box; remove everything from the glove box and remove the three screws holding the bottom panel on. There are four relays there and the flasher is the one in the upper right corner.
Puv is offline
post #2 of 5 Old 11-10-2012, 07:38 PM
gs69350
Not to bring back an old thread, but I have been searching for a minute now, and this is the only post that I've found that gives me hope... Is the flasher the one I circled in this pic?
gs69350 is offline
post #3 of 5 Old 11-10-2012, 10:36 PM
rcMikeS1990
1994 ZJ
Yes it is. Had to replace mine. Went to jy and grabbed one
1994 Grand Cherokee Limited 5.2L V8 318, Spectre cold air intake, Flowmaster Super44 muffler to 3.5" resonator tip, 30x9.5 BFG A/T's, Custom Tranny and TC shifter mod
My Build Thread--not sure how to make that the link-http://www.jeepforum.com/forum/f13/my-build-thread-1568707/
rcMikeS1990 is offline
post #4 of 5 Old 11-11-2012, 01:24 AM
KoreaZJ
1994 ZJ
Correct.
For 95...
A = Vehicle Theft Alarm
B = Horn
C = Door Lock
D = Door Unlock
E = (unused)
F = (unused)
G = Power Antenna
H = Heated Rear Window
J = Electronic Flasher
K = Illuminated Entry
KoreaZJ is offline
post #5 of 5 Old 04-30-2015, 07:30 PM
txcutie40
If that is the flasher and I replaced it and my hazards light up but do not blink and my signals still don't work then what else could the problem be...is there another fuse for the signals and hazards besides the one in the fuse panel on the passengers side when you open the door?
txcutie40 is offline
94 zj , flasher , relay , turn signal
ZJ Flasher Relay Location iflingmud ZJ Grand Cherokee Forum 7 08-14-2012 08:27 PM
Need help with turn signal/flasher relay location 94 zj darren2569 ZJ Grand Cherokee Forum 3 08-03-2009 05:32 PM
flasher location Bearee WK Grand Cherokee & XK Commander Forum 1 07-27-2008 03:33 PM
Flasher Eyeguy77 ZJ Grand Cherokee Forum 0 11-02-2007 10:12 AM
1999 Jgc Flasher Unit Location Help !asap skatingbo ZJ Grand Cherokee Forum 3 05-19-2006 08:34 PM
