fixing the windshield washer fluid - JeepForum.com
post #1 of 9 Old 06-02-2007, 08:57 AM Thread Starter
doveign
hey,
my windshield washer fluid doesn't work, i figured out the problem, it's spraying but it's not coming to the windshield, i tried to fix it but i couldn't take off the plastic that covers the windshield wipers, the fluid is spraying right under there. can someone tell me how to remove the plastic covering from off the wipers??????????
thanks thanks thanks thanks thanks thanks thanks
1999 Jeep Grand Cherokee Laredo L6 4.0L
doveign is offline
post #2 of 9 Old 06-02-2007, 10:28 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
year? 78910
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 9 Old 06-02-2007, 11:15 AM
nashmd454
nashmd454's Avatar
could it also be that the nozzels are clogged....maybe get a small needle and clear up the sprayers...maybe.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #4 of 9 Old 06-02-2007, 12:01 PM
10achik
I ate what?
10achik's Avatar
My guess is that little Y connector that seperated the right and the left has a hole in the membrane and when you press the switch the fluid is going out of the hole. to get to it, all you have to do is remove the two plastic screws and then take off the wiper arms. You can find new Y connectors at any auto parts store, or fix it yourself by cutting a new membrane from a pair of latex gloves.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #5 of 9 Old 06-05-2007, 06:49 PM Thread Starter
doveign
taht's the problem, the fluid is working but i can't take off the wipers
doveign is offline
post #6 of 9 Old 06-05-2007, 06:54 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Dude, help us to help you. Put some specs in your sig. I that your own poetry? It doesn't help us, sorry
zaq123 is offline
post #7 of 9 Old 06-12-2007, 11:41 PM Thread Starter
doveign
hmmmmm
the problem is that i can't take off the wipers, is there something special you gotta do?
doveign is offline
post #8 of 9 Old 06-13-2007, 09:23 AM
dunno513
go buy a small wiper puller. resembles a small gear puller. Yank those off, then pull the clips out securing the plastic panel.
I had this happen to a 96 GC. You may only need to pop the fasteners off to pry up the cover enough to gain access, but I would just pull the wiper arms and cover and clean in there while off.
Oh, and trim that hose back .5 inches so its a new tight fit.
dunno513 is offline
post #9 of 9 Old 06-13-2007, 09:55 AM
LeroyJMC
1994 ZJ
There's probably a nut holding each one on the splined shaft. I have no experience with these wiper arms in particular, but generally there is a single 12-14 mm nut that holds the arm on the shaft. See if there is a plastic cover over the nut.
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is offline
Windshield washer fluid wont spray froggo27 ZJ Grand Cherokee Forum 5 08-15-2008 01:01 AM
Windshield Washer Fluid Problems. 3bqruk ZJ Grand Cherokee Forum 6 12-01-2007 01:56 AM
windshield washer fluid tank Drenyce311 ZJ Grand Cherokee Forum 12 06-22-2007 07:57 PM
windshield washer fluid reservoir cliff WK Grand Cherokee & XK Commander Forum 3 02-04-2007 01:01 AM
'93 GC windshield washer cobra652004 ZJ Grand Cherokee Forum 2 02-22-2004 08:18 AM
