Fixing my death wobble, center front axle, help - Page 2 - JeepForum.com
post #16 of 23 Old 05-11-2010, 07:53 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Speed Bleeders only take a few days to get in
For the trackbar, I found that it works really well to drop the old one, bounce the front a few times, and it just about centers itself perfectly.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #17 of 23 Old 05-11-2010, 08:27 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by rugermack View Post
Buy one of those little vacuum bleeders.
Originally Posted by FPKites View Post
Speed Bleeders only take a few days to get in ....
You guys have to rub it in, don't ya?
I know, I need something.
Wheelin98TJ is offline
post #18 of 23 Old 05-11-2010, 08:42 AM
rugermack
Just messin with ya, They are a handy tool, good for checkin vacuum leaks too.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #19 of 23 Old 05-11-2010, 11:52 AM Thread Starter
bigzj
Hey thanks guys. So i guess what i'm gunna try first is just take off the old bar, back it up, turn the wheel a couple of times to center it up, and extend the bar to the holes with the weight on it. Drive it around the block to let everything settle and measure it to make sure its centered. extend it as necessary. I guess thats a pretty good compilation of everything i've gotten from here.
bigzj is offline
post #20 of 23 Old 09-06-2010, 09:30 PM
xj20004x4
I installed LCA's and had the same problem about 2-3" off. i tightened everything down and dropped it on the ground. im going to try wratchet straps to a tree since there is nothing in my garage and i ripped out my workbench trying to use that. I hope this works! any advice on something else could be helpful too!
xj20004x4 is offline
post #21 of 23 Old 09-06-2010, 10:00 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Just get the bushing in there and turn the wheel a tiny bit - if you hear it squeak, it's moving. Generally won't drop out. This can be done solo, but it's nice to have a partner.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #22 of 23 Old 09-07-2010, 08:08 AM
Wheelin98TJ
JEEP FREAK
You should torque the control arms and track bar when the tires are on the ground.
Doing it with the tires in the air can put a preload on bushings and wear them out quicker.
post #23 of 23 Old 06-05-2013, 05:13 PM
coach-mike
I just did this yesturday and since this thread is from 2010 I really hope your all good by now.LOL I used a rope on the steering wheel and tied it to my tube doors got the bolt in then did an alignment via the draglink worked great..
coach-mike is offline
front left tire death wobble..HELP! zjbullington ZJ Grand Cherokee Forum 2 05-06-2010 12:52 AM
is it death Wobble? zedjay95 ZJ Grand Cherokee Forum 1 03-27-2010 05:58 PM
Front End Loose and Wobble..Periodic, not death 97JPCHRKLRDO ZJ Grand Cherokee Forum 10 02-27-2010 05:01 PM
CV axle cause death wobble? alivenkickin28 ZJ Grand Cherokee Forum 3 09-03-2007 06:12 PM
Front end rebuild parts list (death wobble) TRUNKS ZJ Grand Cherokee Forum 3 08-27-2006 02:12 PM
