Fixing lazy PCM. New caps writeup. - Page 5 - JeepForum.com
 1Likes
post #61 of 169 Old 03-21-2011, 11:38 AM
LagartoJuancho
Works for newer type computers too!!
Guys, I'm happy to announce that this solution also applies to newer type PCMs in XJs!!!
I just repaired mine yesterday and it starts in a split second now!!
They actually ARE THE SAME CAPACITANCE, VOLTAGE AND TEMP RATING as the ones depicted in this thread. The disassembly is a bit more challenging AND you have to be a bit more careful, but as I can testify, they're quite repairable...
I'll be posting some pics soon in a new thread for you to peruse.
LagartoJuancho is offline
post #62 of 169 Old 03-22-2011, 07:15 AM
LagartoJuancho
Link to post
here is the writeup, in case anyone needs it
post #63 of 169 Old 07-14-2011, 03:55 AM
mike_breaker_5
old thread. posting to sub. after replacing sensors, relocating grounds, and pulling out hair i am glad i found this thread. i hope this works.
to all those that bought the 85 degree rated caps where do you live? it was 80-90 degrees here last week and over 100 a month ago. does radio shack have higher rated caps that will work? i'm electronics retarded and would need help getting the correct cap.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #64 of 169 Old 07-14-2011, 07:16 AM
stancomm
85C caps.
First off, consider how long those dreaded 85C guys held out before they rolled over. 1996 to 2011, not too shabby.
If that's what you were able to get and use, well they shouldn't leave you stranded for a good while. Also, that's 85 degrees Celcius, or a 185 Farenheit, pretty darn hot!
The 105C guys can be had from an outfit name of Mouser Electronics... good folks. Their website takes a bit of getting used to, but does work.
Stan
stancomm is offline
post #65 of 169 Old 07-14-2011, 08:16 AM
JS97ZJ
An engine bay can get up to 250* F in the summer. The electronic components in motor vehicles are designed with that kind of atmosphere in mind. RS doesn't carry automotive components. They make their living selling phones and ipods.
Mouser or Online Components deal with all electronic genre. Look in their Automotive components drop-down lists.
JS97ZJ is offline
post #66 of 169 Old 07-14-2011, 06:07 PM
mike_breaker_5
Stan
i was thinking F not C. i think i'll try my luck with the 85c rated. at very least i'll find out if that's my problem, and after they go bad again i can get the higher temp rated caps. thanks for the info folks!
post #67 of 169 Old 07-14-2011, 06:35 PM
JrMechanic
I used the 85c capacitors from Radio Shack 3 years ago and have had zero issues since.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #68 of 169 Old 10-26-2011, 09:21 AM
gamble
Stupid question. Isn't this the tcu? My PCM has 3 plugs on it.
98 ZJ -4.0L
Lots of welders and cnc table
gamble is offline
post #69 of 169 Old 10-26-2011, 09:44 AM
JS97ZJ
This is for the 93-95 PCMs
JS97ZJ is offline
post #70 of 169 Old 11-29-2011, 09:33 PM
oldmancrash
OMG Thank you for this writeup. I have a lot less hair now and so do some of my friends that still will talk to me. I hope to take tomorrow afternoon off just to fix this dang thing.
oldmancrash is offline
post #71 of 169 Old 12-03-2011, 12:37 AM
oldmancrash
Thank you very much for the very helpful write-up. My jeep now starts and even seems to run much better. Thank you
post #72 of 169 Old 12-03-2011, 05:22 PM
jeep210
Glad to see that this solved your problem.
jeep210 is offline
post #73 of 169 Old 12-13-2011, 10:38 AM
dalton1234
help my guys!!!! i have a zj and i recently replaced coil, pick up coil, crankshaft sensor, fuel pump, ecm and coil.. and it will start sometimes and sometimes it wont..... anyone have any suggestions ?
dalton1234 is offline
post #74 of 169 Old 12-13-2011, 11:12 AM
JS97ZJ
Post the problem and symptoms in a new thread. No one is going to look into an old thread to help solve a new problem.
JS97ZJ is offline
post #75 of 169 Old 02-23-2012, 11:04 AM
elkski
I know this is an old thread but I was looking to order some 105C caps from mouser (also digikey is out of stock) and they are back ordered for the UTT ones.. they do have UHE and some others... SOme say they are water based and not for Auto applications.
Anyone have a good place to order the higher temp ones. I see many radio shack 85C ones worked ok but I figured if I ordered the right ones they would be here in no time.
elkski is offline
CarlCarlsen
Lazy WJ?? GrandHokie96 ZJ Grand Cherokee Forum 6 07-26-2009 08:09 PM
99 GC Limited Lazy Shift to 3rd. Islesfan079 ZJ Grand Cherokee Forum 1 07-05-2009 09:40 PM
Lazy PCM, Capacitor replacement how-to? Steve Bohnen ZJ Grand Cherokee Forum 6 01-01-2008 10:27 AM
Lazy mirror!?! froggo27 ZJ Grand Cherokee Forum 4 05-31-2007 04:50 PM
lazy quadradrive trek96 WJ Grand Cherokee Forum 1 11-01-2003 06:18 AM
