Fixing lazy PCM. New caps writeup. - Page 4 - JeepForum.com
 1Likes
post #46 of 169 Old 03-02-2011, 09:24 AM
JS97ZJ
Originally Posted by Dyn0mitemat View Post
I had the exact problems described in this thread in my 98 zj (3 plug pcm) and I pulled it apart with no luck. There was only one cap in it and it tested good.
Ended up replacing it and everythings been bliss since.
Did you re-solder the pins to the 4 connectors to the board?
JS97ZJ is offline
post #47 of 169 Old 03-02-2011, 10:02 AM
classicmetalman
Did you replace the cap or the whole PCM?
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #48 of 169 Old 03-02-2011, 10:43 AM
Dyn0mitemat
No, everywhere I looked and asked they said it wasn't worth messing with the newer (98) 3 plug pcm's because there wasn't anything I could do to fix it.
The pcm
Dyn0mitemat is offline
post #49 of 169 Old 03-02-2011, 11:00 AM
classicmetalman
Thanks DynO,
Care to drop the name of the company you got your PCM from?
Robert
93 Laredo 4.0
96 Limited 4.0
post #50 of 169 Old 03-02-2011, 11:08 AM
Dyn0mitemat
Thanks DynO,
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
Thats the auction I won. Had to send core back in, but it has lifetime warranty
post #51 of 169 Old 03-02-2011, 11:29 AM
classicmetalman
Thank you. Glad you got your problem solved
Robert
93 Laredo 4.0
96 Limited 4.0
post #52 of 169 Old 03-02-2011, 11:36 AM
Dyn0mitemat
Yup, was a PITA trying to find out what it was though. Best part too was that I just bought the truck and drove it out of this guys driveway and about 2 hours later it dies and wouldn't start. Didn't have fuel, nothing back there, so I bought a fuel pump on the way home from work, and luckily figured I'd try to see if there was power back there for the pump, and saw it wasn't getting power.
Took the pump back...
I didn't know what to do at that point, I check fuses and wires etc, thinking something electrical went.
Decided to see if I was getting spark, and I wasn't getting that either. Decided it was the cps (crank position sensor).
Bought one of those, and when I was about to install it, it dawned on me that it couldn't be that, because it wouldn't cut fuel when you turn the key on (when it normally 'primes' the fuel pump). As even if the sensor was bad, when the engine is stopped (as in, before you turn the key to start, having it in the on position) it doesn't relay anything to the pcm anyway, so it wouldn't matter.
Decided to get pcm ordered.
Whats odd though, is it was on/off a few times. Twice it randomly started, we thought it was just a loose wire or connection somewhere from messing in the engine bay. It would run like a champ, and then come out of the store and it wouldn't start.
Put the new pcm in and she started right up though. No problems since
post #53 of 169 Old 03-05-2011, 10:55 AM
Garryjav
been over a year since i fixed mine with the radio shack parts and its stil working everyday
Garryjav is offline
post #54 of 169 Old 03-05-2011, 07:05 PM
neonhomer
There has to be a way to dissolve that damn potting material. If I could get that stuff off, it would be easier to try to track down problems on the board. Most likely, a majority of all PCM failures are from a component failure, not a IC failure....
neonhomer is offline
post #55 of 169 Old 03-05-2011, 10:54 PM
JS97ZJ
JS97ZJ is offline
post #56 of 169 Old 03-18-2011, 01:34 AM
austinaubinoe
Ok Ive gotten to the point where I have cut away at the gel around the old Caps and where they are soldered to the board. I have the Radio Shack caps in hand. My question is, how do I determine which side is negative, and which is positive?
austinaubinoe is offline
post #57 of 169 Old 03-18-2011, 05:59 AM
greasefingers
greasefingers's Avatar
1994 ZJ
One of the two leads to the cap is longer. This is usually the positive.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #58 of 169 Old 03-18-2011, 06:22 AM
LagartoJuancho
Polarity
Also, the caps have the polarity printed in their plastic sleeve. Usually a band of different color that runs through the cap and has either a bunch of dashes (indicating that side's lead is negative) or pluses.
Use what's printed on the cap to be replaced as reference (assuming you haven't pulled it out yet) and just stick the new cap in the same orientation.
LagartoJuancho is offline
post #59 of 169 Old 03-18-2011, 11:24 AM
austinaubinoe
Ok thanks! My OBD1 board is slightly different then the one originally pictured. It has a steel heat sink instead of an aluminum one.
I think I can figure out the +/- on the replacements, but is there any way to tell on the board if I have already pulled one out? If I have the board in one position, and lets say determine the left side of cap #1 is positive. Can I assume the 2 others are left side positive aswell???
post #60 of 169 Old 03-21-2011, 11:31 AM
LagartoJuancho
Not really. You have to evaluate each cap you're replacing individually.
Lazy WJ?? GrandHokie96 ZJ Grand Cherokee Forum 6 07-26-2009 08:09 PM
99 GC Limited Lazy Shift to 3rd. Islesfan079 ZJ Grand Cherokee Forum 1 07-05-2009 09:40 PM
Lazy PCM, Capacitor replacement how-to? Steve Bohnen ZJ Grand Cherokee Forum 6 01-01-2008 10:27 AM
Lazy mirror!?! froggo27 ZJ Grand Cherokee Forum 4 05-31-2007 04:50 PM
lazy quadradrive trek96 WJ Grand Cherokee Forum 1 11-01-2003 06:18 AM
