Fixing lazy PCM. New caps writeup. - Page 2 - JeepForum.com
 1Likes
post #16 of 169 Old 12-26-2009, 01:44 AM
Bannonjr
wicked! Thanks for the pic...
better get of my arse and get this done.
Your Friendly Canadian Amsoil Dealer!
Red Jeep Club #151
Canadian Jeeps Club Member #25
Bannonjr is offline
post #17 of 169 Old 12-26-2009, 03:16 AM
ZJ5point2GCL
so why would you do this? is it basically just for no-starts ?
ZJ5point2GCL is offline
post #18 of 169 Old 12-26-2009, 09:29 AM
AmbuGrl
AmbuGrl's Avatar
It is for more than no starts. Once you have troubleshot everything else and replaced what you need to replace and that doesnt work, this is another cheap fix to try. It will cost roughly $700 to replace a PCM with the dealer, it will cost less than $4 to fix it yourself with parts from radio shack. We had this issue (without knowing it) We replaced the fuel pump and filter, the ignition coil, the CPS, all of the relays and several fuses(roughly $600) before trying this fix. We found a few threads related to PCM probs before we found the fix from Gomes512. The probs described by others were indentical to ours. We had no CEL light at all, even after replacing the CPS. We figured why not and gave his write up a shot, she started right up and has been fine ever since.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #19 of 169 Old 12-31-2009, 11:25 PM
prplhz96
2005 WK
Any more follow ups on this repair??? How long ago have some of you done this and still have no prior symptoms??? I am sure there are other things in the PCM that can fail, is there anything else I can replace while I am in there as more preventitive maintance?? Thanks in advance for any replies
prplhz96 is offline
post #20 of 169 Old 01-14-2010, 04:55 PM Thread Starter
gomes512
1994 ZJ
I did mine whenever the post was made. No problems, Jeep runs like a top.
The rest of the board should hold up through nuclear winter. I'm curious as to what's under that big 'ol heatsink. Obviously something that puts out heat, I could see that as being a future failure point.
The reason the caps are prone to failing is due to the harsh environment they are in. Constant heat/cool cycles are the problem. The caps in my vehicle information display on the other hand look great.
gomes512 is offline
post #21 of 169 Old 01-17-2010, 03:57 PM
kappa080
The caps
Should the tops of the caps be blown at all? i really think that all my problems ive been having lately are thanks to the pcm but do not want to tear into the board if the caps arent going to fix it. thanks for the thread it helped alot.
kappa080 is offline
post #22 of 169 Old 01-17-2010, 04:42 PM
ZeeJay1997
delete a post???
ZeeJay1997 is offline
post #23 of 169 Old 01-17-2010, 04:42 PM
ZeeJay1997
I'm guessing a voltage regulator for the 5V sensor output. All that extra voltage has to go somewhere.
post #24 of 169 Old 01-17-2010, 04:48 PM
JrMechanic
That looks familiar:
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #25 of 169 Old 01-23-2010, 10:34 AM
Garryjav
thanks for the write up, mine sat for a few months then would not start, messing with it a while it did start, thats when i noticed it would only start when the check engine light came on and found this post.
something that might help others is i only have a 140 watt soldering gun. it really was to big to get in to the small pins on the caps. what i did was to use a pc. of solid coopper wire 12 ga.i think it was and bend up a tip for my soldering gum out of the wire. it gets hot in a instant
Garryjav is offline
post #26 of 169 Old 01-23-2010, 11:24 AM
getoffmyland
the other reason for capacitors fail is due to a counterfeit operation that was / is running. Had a load of computer power supplies and motherboards fail due to capacitor fail. I would guess that the 12v to 5v circuit is failing because of the caps (they form part of a regulator circuit) and then whatever the PCM does is not working.
getoffmyland is offline
post #27 of 169 Old 09-14-2010, 09:10 PM
jeepjoe123
Just to insert
Hey I have the same ecm problem on a 93 jeep grand cherokee. However I noticed that the part number from radioshack on here matched as a 85 C rating. The capacitors you remove from the ecm the 105 C ratings. I read up about that on this post
http://www.jeepforum.com/forum/f9/an...ir-pcm-628371/
That post said that radioshack didnt carry the 105 C rated ones. It does say you can get them from Digi-key. I checked with them and spoke with a tech and he said they did not carry the PL(W) series. He did say that these would be the same though
Digi-Key - 493-3277-ND (Manufacturer - UTT1E221MPD)
I posted because I saw everybody replacing theyres with the 85 C ones. Anyways thats my 2 cents worth after 3 days of thread combing. Props to all for the great info.
jeepjoe123 is offline
post #28 of 169 Old 09-15-2010, 10:35 PM
AUSjeepzj
Gday I was just wondering if you are aware of the same problem with the PCMs on the 1996 models as Im having the same problem with my jeep, I have no power going to the coil and its been traced back to the PCM.
AUSjeepzj is offline
post #29 of 169 Old 09-15-2010, 11:21 PM
iPlay1515
The PCM does not directly supply power to the coil. It supplies ground. However, the PCM does control the auto shutdown relay which in turn supplies power to the coil. Check the relay if you have no power on the coil.
You may have a fault that is keeping the PCM from closing the auto shutdown relay as it should.
iPlay1515 is offline
post #30 of 169 Old 09-15-2010, 11:33 PM
freakinheep89
also, a no power to coil is the main symptom of a CKS fault(crankshaft position sensor), have you eliminated that as an option?
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
Lazy WJ?? GrandHokie96 ZJ Grand Cherokee Forum 6 07-26-2009 08:09 PM
99 GC Limited Lazy Shift to 3rd. Islesfan079 ZJ Grand Cherokee Forum 1 07-05-2009 09:40 PM
Lazy PCM, Capacitor replacement how-to? Steve Bohnen ZJ Grand Cherokee Forum 6 01-01-2008 10:27 AM
Lazy mirror!?! froggo27 ZJ Grand Cherokee Forum 4 05-31-2007 04:50 PM
lazy quadradrive trek96 WJ Grand Cherokee Forum 1 11-01-2003 06:18 AM
