fixed length control arms - JeepForum.com
post #1 of 4 Old 07-11-2011, 11:22 PM Thread Starter
jnjtrevino
1994 ZJ
i am looking at buying the IRO fixed length lower arms front and rear. my question is can i get away with only the lowers or do i have to have the adjustable uppers too?
94 ZJ 3.5 benchmark lift, .75 coil spacers 31 x 10.50, rear adjustable track bar
You laugh because I'm different...........
I laugh cause I just farted!
jnjtrevino is offline
post #2 of 4 Old 07-11-2011, 11:23 PM
WhiteOut
WhiteOut's Avatar
You can do only lowers. I ran only lowers for a while before doing the longarms.
WhiteOut is offline
post #3 of 4 Old 07-12-2011, 01:44 AM
newfieZJ
I'm gonna say this is a mistake for any lift . Buy adjustables for the extra $50ea pr.
1) Adjustability for larger tires and to go higher if desired
2) Re-sale value and ease of sale if upgrading
3) IRO's fixed arms are not a beefy as the adjustables . (I have fixed on my stock 5.9 , Adjustables on my Comanche) Strength ? I'm sure they are comparable
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 4 Old 07-12-2011, 04:44 AM
Technohead
The threaded area on adjustable contol arms significantly compromises strength. That is why adjustables tend to look more beefy.
At the very least you need one pair of adjustables on the rear in order to dial in the pinion angle. Up to about 3" or so, the existing cam bolt adjustment on the front axle can be used to dial in caster/pinion angle and you can get away with fixed length.
-Eric
Technohead is offline
control arm , death wobble
Length of stock OEM rear control arms?? stroked250 WK Grand Cherokee & XK Commander Forum 0 03-29-2010 08:14 AM
adjustable control arms on 3.5" short arms (ride quality) 3xX ZJ Grand Cherokee Forum 7 11-29-2009 12:16 PM
4.5 r.e. lift what is the length of control arms larrysblackZJ ZJ Grand Cherokee Forum 5 05-12-2009 07:12 PM
RE Fixed Control Arms zjeepin ZJ Grand Cherokee Forum 14 01-16-2007 07:41 PM
Adjusting Control Arms for length? Joseph Humphrey ZJ Grand Cherokee Forum 9 02-22-2006 06:05 AM
