fit 33s with minimal lift - Page 5 - JeepForum.com
post #61 of 71 Old 07-02-2013, 10:30 AM
speedbucket
Shocks don't give lift.......ever...if you're at 19 then you have upcountry, someone doubled an isolated or swapped in different springs.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #62 of 71 Old 07-02-2013, 02:33 PM
Area11
Hmm... Im going to get a build sheet. Are there other ways i can tell if its upcountry?
I at 19" from center of wheel to bottom of fender. I also have fog lamps. Other than that there are no skid plates at all, the entire hitch is aftermarket, and some idiot switched the springs.
Area11 is offline
post #63 of 71 Old 07-02-2013, 06:56 PM
tucsonzj
Fog lamps has nothing to do with uc package. Skid plates came on the uc package (IIRC) as well as was an option.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #64 of 71 Old 07-02-2013, 11:49 PM
kg6mov
Hears the voices
kg6mov's Avatar
Hooks and all three skids is a good indication, there was also a window sticker that proudly proclaimed it was upcountry.
kg6mov is offline
post #65 of 71 Old 07-03-2013, 01:14 AM
Area11
On which window is said sticker. I replaced my front drivers side door with a door from a 96.
Area11 is offline
post #66 of 71 Old 07-03-2013, 07:02 AM
tucsonzj
3rd (cargo) on drivers side
tucsonzj is offline
post #67 of 71 Old 07-03-2013, 02:02 PM
Area11
No sticker, Jeep also hasn't sent me my build sheet yet.
Edit: still no build sheet 2 days later.
Area11 is offline
post #68 of 71 Old 07-04-2013, 07:03 AM
tucsonzj
15 yrs old...sticker might have been takin off. You can also visit the dealers service drive, think they can pull build sheet. Took a few days to get mine. Keep ur pants on
tucsonzj is offline
post #69 of 71 Old 07-04-2013, 12:19 PM
Area11
The sticker and everything else that comes with the upcountry except the lift. Tbh the lift is all i care about but it would be nice to know if it came with anything else. I know its all optional though.
Area11 is offline
post #70 of 71 Old 07-04-2013, 07:16 PM
Area11
Dear Jon Doe
Thank you for contacting the Jeep Customer Assistance Center.
We are pleased to provide vehicle build information per your request for
your 1998 Jeep Grand Cherokee Sport Utility 4-Door.
According to our records, your vehicle was equipped from the factory
with the following:
Vehicle Description: JEEP GRAND CHEROKEE SPORT UTILITY 4-DR
Model Year: 1998
Body Model: ZJ J L 74
Sales Code Description
EL Leather Trimmed Bucket Seats
AZ Agate
ADZP Special Edition Group
AFFP Luxury Group
AHCP Trailer Tow Prep Group
APAS Monotone Paint
ARD Radio Cass/CD/8 Infinity Gold Spkr
ARNP Laredo Decor Group
A31P 5.2L Eng(ELF)/4Spd A/T 44RE(DGW)
BAUS 117 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BRGS Anti-Lock 4-Wheel-Disc Brakes
CACS Low Back Bucket Seats
CFNS Rear 60/40 Folding Seat
CGWS Driver & Front Passengern Air Bags
CKDS Floor Carpet
CKNS Cargo Compartment Carpet
CKRS Cargo Net
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CSAS Spare Tire Cover
CSCS Cargo Compartment Cover
CSRS Passenger Assist Handles
CUFS Full Length Floor Console
CUNP Overhead Console
CXHP Steering Column Locking Slip Collar
DGB All 4-Speed Automatic Transmissions
DGWS 4-Spd. Automatic 4RE Transmission
DHAS Lock-Up Torque Converter
DHRP Quadra-Trac "On Demand" 4WD System
DJJS Dana 30/186MM Front Axle
DMEP 3.73 Rear Axle Ratio
DRKP Dana 44/226MM Rear Axle
EAAC All Engines
ELF 5.2L V8 MPI Engine
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGP Deep Tint Sunscreen Glass
GEPS Flipper Liftgate Glass
GFAS Rear Window Defroster
GNCS Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GRMP Left Power Heated Mirror
GSMP Right Power Heated Mirror
GTMP Power Heated Mirrors
GVBC All Vehicles W/Power Mirrors
GXMS Keyless Entry with Panic Alarm
HAAP Air Conditioning
HGAS Hood Insulation
HGDS Deluxe Insulation Group
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JKAS Glove Box
JPAS Power Windows
JPBS Power Locks
JPWP Power Lumbar Adjust
KRSS RADIANT SILVER MET. C/C - DIMENSION
KSSP RADIANT SILVER MET. C/C - Badge
KTSS RADIANT SILVER MET. C/C - Badge
KWSS RADIANT SILVER MET. C/C - Badge
KZSP RADIANT SILVER MET. C/C - DIMENSION
K4XS BLACK CLEAR COAT - Molding
LACS Illuminated Entry
LAGS Warning Chime
LBBS Courtesy Lamps
LBCS Glove Box Lamp
LBDS Ash Tray Lamp
LDAS Underhood Lamp
LDBS Cargo Compartment Lamp
LETP Traveler/Mini Trip Computer
LMGP Automatic Headlamps
LNJP Fog Lamps
LPSS CHMSL Lamp
LSAP Security Alarm
MDAP Front License Plate Bracket
MFZP Bright Grille
MHAS Black Windshield Moldings
MWGS Roof Rack
NAA Federal Emissions
NF5S 23 Gallon Fuel Tank
NHMS Speed Control
NMCP Heavy Duty Engine Cooling
PX8 Black Clear Coat
QX8S Black Clear Coat
RAAC All Radio Equipped Vehicles
RAZP AM/FM Cassette Compact Disc Radio
RCGP 6 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCLP Leather Wrapped Steering Wheel
SDAS Normal Duty Suspension
SUAS Tilt Steering Column
TBBP Full Size Spare Tire
TBLS Inside Mounted Spare Tire
TRL P225/75R15 Wrangler RT/S AT Tires
TZAS Goodyear Brand Tires
WJZP 15X7 Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
YAAS Build To U.S. Mkt. Specifications
Our records indicate that the following recall campaign(s) have not been
performed by an authorized dealer:
B02 FLOOR SHIFTER SECONDARY DETENT SYSTEM SAFETY 09/19/2002
INCOMPLETE
I still dont understand why i have a one inch lift.
Area11 is offline
post #71 of 71 Old 07-05-2013, 10:41 AM
tucsonzj
Either special edition group, different tire size, or po changed something
tucsonzj is offline
