fit 33s with minimal lift - Page 3 - JeepForum.com
post #31 of 71 Old 05-06-2013, 02:55 PM
BuzzZJ9er
Originally Posted by kg6mov
My new niner trans ended up being new mopar, we couldn't find anything else that was worth it.
How much did that run you?
BuzzZJ9er is offline
post #32 of 71 Old 05-06-2013, 03:07 PM
kg6mov
Hears the voices
kg6mov's Avatar
I don't remember what the break down was. I ended up being out the door with new to me engine (tested w/ warranty) and new mopar trans for $5k
kg6mov is online now
post #33 of 71 Old 05-06-2013, 03:19 PM
BuzzZJ9er
Ouch.. I can't afford nothing like that!
post #34 of 71 Old 05-06-2013, 03:29 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
33's will fit on just a BB with either trimming, or bump stopping to. one way or another you gotta keep them out of the fenders.
i chose the cut to fit method with no extra bumpstopping and ran 34's on a BB'd Up country ZJ for a while. Acutally, the same jeep is getting 36's very soon still on the same lift.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #35 of 71 Old 05-06-2013, 05:19 PM
Concolour
1994 ZJ
I don't see this ending well ::cringe::
Concolour is offline
post #36 of 71 Old 05-06-2013, 06:03 PM
underpowered
It won't, and we know it.
there is a D44 and 14ff waiting to go in, but figured might was well fully finish off the d30/35 before they are removed. The jeep gets one last hoorah as a jeep before it is hacked up and tubed out.
post #37 of 71 Old 05-09-2013, 09:49 AM
tucsonzj
I am getting the same set up, ill stay at 31s. Id like to be able to flex.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #38 of 71 Old 05-09-2013, 10:16 AM
Timo_90xj
Timo_90xj's Avatar
I myself really don't see a point in going sky-high to fit something like 33s or 35s. My ideal setup would be around 3" lift on long arms (rear double triangulated, front 3-link), enough chopping & modifications on the wheel wells and 35s or 37. It can be done nicely and cleanly, but that'd certainly require quite a bit of sheetmetal work
I drove my ZJ with 1.75" BB and 32s for a couple months without major mods to fenders, and didn't rub at all. I adjusted the WB a little (~1.5" stretch at both ends). I then partially rebuilt the wheelwells, I could now easily run 33s, and 35s with ~1"-2" more bumpstopping (in which case I'd have a bit too little uptravel in front, so a 1"-2" lift would do some good).
Currently still running 1.75" BB and 32s, can't say the flex is limited at all..
***Under construction***
Timo_90xj is online now
post #39 of 71 Old 05-09-2013, 10:48 AM
kg6mov
Hears the voices
kg6mov's Avatar
Good christ thats a sexy looking niner.
post #40 of 71 Old 05-09-2013, 11:46 AM
Timo_90xj
Timo_90xj's Avatar
That was before the front bumper was fully completed. It looks better now
But thanks!
post #41 of 71 Old 05-09-2013, 03:36 PM
underpowered
still had full suspension cycle on 34's, though with liberal fender mods.
Agreed, LCOG is great. On the 95 i mentioned above it will stay on about 3" of lift on the 36's, granted it is getting full widths and the exact suspension you listed ( double Tri 4 link rear and 3 link front) but keeping only 3" of lift, though it is losing nearly the entire body however.
I only run 3" of lift with 38.5's on my k5 blazer, and only what i consider light fender trimming and no rubbing what soever.
post #42 of 71 Old 05-09-2013, 04:19 PM
tucsonzj
Yup, that's one of the things I'm missing
tucsonzj is offline
post #43 of 71 Old 05-09-2013, 08:01 PM
misfit4lo
God I love cutting sheet metal.
misfit4lo is offline
post #44 of 71 Old 05-09-2013, 09:02 PM
spidermonkey
Fit is a relative term. It entirely depends on what you use it for.
I wheel mine moderately hard, flex a lot, big rocks, tight trails.
Use stock wheels with 1.25 spacers or 7" wide wheels with 3.75 backspacing. with 33x10.5s. 8" wheels with 12.5s can work but it is harder. I know.
I cut and folded the rear half of the pass side rear wheel lip, (behind the tire inside the wheel well), or the tire will catch it and cut it up like I did. Driver side not an issue. No bump stops required in back if you have a stock axle. it will tuck a 10.5. With the narrower 8.8 and 33s they will tuck a 12.5" in the wheel well lip barely.
Cut the front fender about half way up the stock stamped flare of the fender.
Remove front inner fenders. It works good but all the crap that flies off the tires now gets in your door hinges. A minor side-effect.
Cut slits in the pinch seam at the rear of the front wheel well.
At the front of the front wheel well, trim and trim the obstructing inner fender support as needed, but no more.
Bump stop just enough so the tire doesn't grab the fender or inner when the tire is all the way up in the wheelwell. I used 2 hockey pucks RTVed, plus the factory stops. Don't laugh, work perfect and cheap!
lift it 3-3.5" any less will hit the accurate bump stops just hitting street bumps. You would have 2" or less of up travel. You can get away with less lift if it is a pavement queen or you like a crappy ride. I am picky as all hell and it took me 4 years to figure it out.
In my 9 years of wheeling, 31s with stock gears will almost always go were a rig on 33's can but the guy on 31's doesn't need new gears, a new rear axle, or to chop the hell out of his rig. I have no regrets, but it would be easier to stay on 31s.
Good luck!
98ZJ, 4.0,242, 8.8 Detroit, hp30, 3.5" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here:
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers
spidermonkey is offline
post #45 of 71 Old 05-09-2013, 11:16 PM
tucsonzj
I cut and folded the rear half of the pass side wheel lip back or the tire will catch it and cut it up like I did. Driver side not an issue. No bump stops required in back if you have a srock axle. it will tuck a 10.5. With the narrower 8.8 and 33s they will tuck a 12.5" in the wheel well lip barely.
Good luck!
You sir, just made my life easier.
tucsonzj is offline
