First time Jeep owner checking in. - Page 2 - JeepForum.com
post #16 of 28 Old 04-21-2013, 03:16 PM
kg6mov
Hears the voices
kg6mov's Avatar
For suspension if you're not lifting, start with new shocks all around, new CA's up front and maybe in the back, sway bar links and bushings.
kg6mov is online now
post #17 of 28 Old 04-21-2013, 04:19 PM Thread Starter
StrateLOSS
I appreciate this guidance, I am currently draining the engine oil and peeked underneath for the first time and these areas where the exact places that were most worn.
I'd like to lift and if I did I would do the baby boost so I'd need shocks to accommodate that.
Curious if you have any specific recommendation on a cost effective shock? This Jeep will not see any high speed, or rock terrain etc, just pavement and maybe some amateur dirt here in NYC if I can find anything.
Sent from AutoGuide.com Free App
StrateLOSS is offline
post #18 of 28 Old 04-21-2013, 04:22 PM Thread Starter
StrateLOSS
lower control arm bushings look shot
sway bar endlinks are toast
balljoints appear acceptable to me
I'm just not sure if the above is supposed to look like this or if parts are missing.
these bars looked good, no tears and they're greasable
post #19 of 28 Old 04-21-2013, 04:34 PM
kg6mov
Hears the voices
kg6mov's Avatar
The axle shaft looks fine, you've got U'joints so no boots.
post #20 of 28 Old 04-24-2013, 05:24 PM Thread Starter
StrateLOSS
changed front diff fluid yesterday
rear diff fluid today
also just finished this, tb and iacv cleanup
this thing turned copper
post #21 of 28 Old 04-25-2013, 03:29 PM Thread Starter
StrateLOSS
p041 code came up the other day, so I checked the fuses and all good, next up was the wiring for any breaks and I find this( I unplugged and brought the harness to the drivers side)
hard to focus the iPhone camera.
I went under to do the transfer case so I did this too, these breaks were touching behind the tape and stuff.
I fixed the wiring, rerouting and reconnected it, topped off the TC with ATF.
Transfer case moves much easily now inside the cab but my CEL code is still on since I didn't clear it or disconnect the battery due to the kill switch.
The short may have fried the o2 though but I'll clear the code tomorrow.
I also adjusted my TV cable which was way on the lazy shift side, haven't drove it yet but I will tonight when I go to AutoZone for some relays for the PDC.
Also fixed my interior lighting not working, put the fuse in and they wouldn't shut down no matter what but I fixed that and they're working perfect.
post #22 of 28 Old 04-25-2013, 06:45 PM
PHARIS88
How did you fix the interior lights? I noticed mine flicker and dim and get brighter etc... Was it a fuse?
Anybody can be become an American, you have to be BORN TEXAN!
PHARIS88 is offline
post #23 of 28 Old 04-25-2013, 06:53 PM
dusterdude
Your cel will stay on for a specific number of on-off key cycles,i dont know how many
dusterdude is offline
post #24 of 28 Old 04-25-2013, 07:50 PM Thread Starter
StrateLOSS
First I put in the fuse then they wouldn't shut off.
Then I traced down that down to the rear hatch light being pushed it. Wouldn't shut off.
Then the dimmer switch was on blast, finally shut off.
Then flickered when my headlights were on, traced it down to the rear passenger side door. Adjusted the button and all good now.
post #25 of 28 Old 04-25-2013, 07:52 PM Thread Starter
StrateLOSS
I see, I was impatient so I had it cleared earlier, it's off right now so I'm playing the wait game to see if it comes back on or what and what code it throws. If it's the same code then I know the break in the wires fried the o2 sensor and I will replace it.
post #26 of 28 Old 05-01-2013, 08:56 PM Thread Starter
StrateLOSS
did a lot of work these past days
dropped the pan, changed the filter, added a drainbolt, and poured in badly needed ATF.
changed the o ring on the iacv
sparkplug and wire set
also adjusted the tv band
Jeep is coming along nicely, tomorrow I *may* check the female pins on the ecu harness connector, I can stall the Jeep by pushing on the gray plug.
I'm not having stalling issues other than me messing with the harness so I may just ziptie it, would love some pictures on how people accomplished this.
post #27 of 28 Old 05-03-2013, 08:51 PM Thread Starter
StrateLOSS
I had an exhaust rattle I wanted to get rid of, I went to autozone and got a generic hanger to replace the brittle one underneath.
That partially removed the rattle(well the creeking), I was getting noise from the actual muffle itself. So I went to tighten the clamps on the muffler, it snapped.
So I snapped the rest off thinking I'd hammer out the muffler from the cat and rear pipe and replace it since the muffler is bent anyway, didn't happen.
The metals are fuzed together, so now no clamps. Well turns out that got rid of almost all my exhaust rattle. Good: no rush for a muffler.
I then wrapped it up on the Jeep early and didn't get to do the ecu harness cleaning and pin adjustment/ ziptie mod. Swapped suspension and rear sway bar on my friends Civic Si instead.
post #28 of 28 Old 05-03-2013, 09:02 PM Thread Starter
StrateLOSS
So today I get to the Jeep and it barely started after long cranks, sputtered until it de-flooded itself, idled a few seconds then cutoff.
Did this 2 more times until it finally decided to stay on, but it threw the CEL. 5 codes, oh well.
Got back home and did this
removed ecu, cleaned the pins with electronic cleaner, cleaned the harness, fixed up the female pins on the harness a little, then reinstalled everything nice and tight.
I ziptied the gray harness since that was the culprit, I use two zip ties to doubly secure it. The other two harnesses gave me no issues but ai gave them a ziptie each for good measure.
Jeep is running really really good right noe. Gas gauge isn't on/off anymore, idle kicked down 100 rpm almost.
