First thread and really need some help please - JeepForum.com
post #1 of 20 Old 12-07-2009, 10:09 PM Thread Starter
crgeltn
I just purchased a 1995 grand cherokee orvis 4.0 awd. My family really needed this vehicle as my truck just died and my wife and I needed something to get back and forth to work. Yes, times are tough and we will have to share, dropping each other off and such. Long story short, I looked at it, drove it around a parking lot, rebuilt motor, rebuilt tranny,(have paperwork) all the fluids looked ok, ect... Scraped up the last bit of cash we have to buy it. Drive it home and of course really loud whine from the left front when driven over 30 mph. Too bad I did not go any faster around the lot! Any idea of what is is? Very expensive fix? Also, can I drive this thing safely without the front driveshaft for a while if that makes a difference? Like I said, we are basically out of cash for now and screwed if we can not use this thing! I really could use any advise/help please.
crgeltn is offline
post #2 of 20 Old 12-08-2009, 08:01 AM
Turbonut
I've never tried that, but here is some reading, but guess you better have a good/working e-brake:
http://www.jeepforum.com/forum/f13/9...eshaft-327619/
Front driveshaft removal for sure? - North American Grand Cherokee Association
Driving without front driveshaft? - Car Forums and Automotive Chat
If it is in the front/wheel, removing the shaft won't change the noise, but at least it will be a good test.
Turbonut is offline
post #3 of 20 Old 12-08-2009, 08:06 AM
JrMechanic
If it's for sure whining from the front left, it's most likely the hub bearing. Jack up the front of the Jeep and grab the tire. Wiggle it back and forth to see if there's any play in the hub.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #4 of 20 Old 12-08-2009, 08:13 AM
blackjack12982
1994 ZJ
x2 on what JrMechanic said. Try to move the wheel side to side, and up and down with that side jacked up. If there's any play, then your hub bearing assembly is shot.
Not too difficult a fix, but you'll definitely want a big a** cheater/breaker bar to help.
blackjack12982 is offline
post #5 of 20 Old 12-08-2009, 08:13 AM
troys96xj
Drive it and turn the wheel left then right . If the noise is louder one way and goes away the other way then its that wheel bearing. Left turn louder then its the right , if louder in right turn then its the left. About $50 on E-bay and pretty easey to do. Good luck.
troys96xj is offline
post #6 of 20 Old 12-08-2009, 08:33 AM
highlyuncntered
Most likely the wheel bearings. I picked up a set of u-joint front axle shafts with bearings for $35 at the JY. Both sides.
"Si Vis Pacem, Para Bellum"
'98 ZJ Limited V8 "Daisy"
highlyuncntered is offline
post #7 of 20 Old 12-08-2009, 09:12 AM Thread Starter
crgeltn
Thanks for all of your replies. Just came back from the shop this morning. They did a quick drive and threw it up on the lift for a quick check. They checked the oil in both pumpkins and it was fine. They checked the front and rear for any noises, anything loose, leaks and found nothing. They found a leaky seal on the transfer case and topped the transfer case off with 2/3qt fluid. Noise is still there although not as pronounced. They are thinking something in the transfer case or possibly just the seal. They also were thinking possibly wrong trans fluid or someone had topped off with the wrong fliud as the transmission was a little overfilled. I am dropping the truck off on Monday for a more detailed look as the mechanic I usually deal with is on vacation and usually is the one there that works on jeeps/4x4s. They also were great and didn't charge me a thing. Any opinions? Anything in particular I should ask them to check? Are they totally off base? I welcome any and all opinions. And thanks again!!!!!!!
I really hope to post/read lots more on this forum as I really love this Jeep. I do have some mechanical ability but am by no means a mechanic.
I'm gonna go read some of the links and FAQs now.
crgeltn is offline
post #8 of 20 Old 12-08-2009, 09:16 AM Thread Starter
crgeltn
Oh yeah forgot to add, the whining just seemed to come from the left front as I only had that window open and it is closest to the transfer case.
crgeltn is offline
post #9 of 20 Old 12-08-2009, 09:20 AM
FirefightinWJ
Another way to test a front wheel bearing is to "weave" from left to right while drive down the road. If the sound quits when you weave from left to right, chances are it's your front left wheel bearing.
LET'S GO PSU
04 WJ Laredo I6
5.5" IRO CP
32" BFG M/Ts on JK 17's
-Devin
FirefightinWJ is offline
post #10 of 20 Old 12-08-2009, 09:35 AM Thread Starter
crgeltn
The noise is constant but quiet when moving but when I am on the gas, under load, or the faster you go the louder it gets. When you let off the gas the noise is still there but barely noticeable and only there while the jeep is moving. I also forgot to mention I looked at the tires this morning and they are big, new 31x 10.5 Bridgestone Dueler A/Ts. There is no rubbing or anything but not sure if that would have anything to do with it. It is definately not tire hum though.
crgeltn is offline
post #11 of 20 Old 12-08-2009, 09:47 AM
TowMaster
When you say that the noise is more pronounced when accelerating slightly concerns me. If it's a wheel bearing problem you should hear it about the same with relation to the speed. You NEED to pay attention to what these people have said or you shouldn't have posted. Put a jack under your front pumpkin and jack it up until your left front tire is off the ground and wiggle the darn tire. If it doesn't wiggle than it could be in the front pumpkin, or in the transfer case.
NightCrew #125
Why don't they have braille at drive-thru's?
TowMaster is offline
post #12 of 20 Old 12-08-2009, 10:17 AM
bigbluebowtie
I agree with the above poster. Please try what they say, that will eliminate all possibilities of the wheel bearing and then we can move on to the next step. If it is more pronounced when it is under acceleration and still there on deceleration, it sounds like a pinion bearing to me. Try this, accelerate up to speed and once you get to speed, let off just slightly, enough to take the load off of the drivetrain, if the noise stops just for a second and then starts again when the load is on the drivetrain for deceleration, it most likely is the pinion bearing. Take my information however you see it, but that is my opinion. I know I haven't been on the site for a long time, but I am a DIY mechanic (not a professional) and have lots of experience in the field. Good luck.
BBB
1995 Jeep Grand Cherokee and several other vehicles, too many to list.
bigbluebowtie is offline
post #13 of 20 Old 12-08-2009, 01:46 PM Thread Starter
crgeltn
Thanks for posting and sorry if I wasn't clear in my more recent posts. I AM paying attention. At the shop they checked for wheel bearing noise. Yes, they yanked on all four wheels. They also checked for noise in both pumpkins while on the lift and they found none. That is why they were leaning more toward the transfer case as it was leaking (not bad) but was 2/3qt low and the seal is bad. Once they check it out further on Monday I will post again. Again, is there anything else I should have them check?
crgeltn is offline
post #14 of 20 Old 12-08-2009, 04:52 PM
bigbluebowtie
Hmmm. Did they check the vehicle just on the hoist or while driving too? They should check while driving, because without a load on the axles, it may not make a noise at all! I wish I could drive it for you so I could hear it...
BBB
post #15 of 20 Old 12-08-2009, 06:15 PM
Andymack
The front diff could just be low on fluid. Try checking that...
- = AnDyMaCk = -
Andymack is offline
Yet another CKP Thread grw800 ZJ Grand Cherokee Forum 3 10-01-2009 08:15 PM
thread gone ? retroron ZJ Grand Cherokee Forum 4 04-07-2009 09:46 PM
Another IRO LA Thread.... nierace ZJ Grand Cherokee Forum 50 05-20-2007 10:54 PM
Not just another DW thread.. rustycherokee18 ZJ Grand Cherokee Forum 7 11-25-2006 08:08 PM
VS. thread i have 5 jeeps ZJ Grand Cherokee Forum 14 04-11-2005 08:55 PM
