First Purchase Inquiry - JeepForum.com
post #1 of 11 Old 11-12-2013, 12:04 PM Thread Starter
ShugaWataPurple
Hey guys,
Looking to become a fellow Jeep owner
the one I'm currently interested in now is a 1995 Grand Cherokee Limited 4L i6 at 280km
I've provided the ad here:
http://vancouver.en.craigslist.ca/bn...159947321.html
anything in general that I should just watch out for when considering this vehicle?
or anything that is a huge red flag in this specific ad?
I don't know a lot about these cars but I gotta start somewhere right?
Appreciate the input
ShugaWataPurple is offline
post #2 of 11 Old 11-12-2013, 12:19 PM
JasonStebbins
It looks and sounds really good. And it's been owned by the family which is another plus. I want those marshmallow seats.
There's a 100 different things you can check, but it's the 4.0L with the 242 transfer case so the biggest things I would look for are bearing noise in the differentials, exhaust manifold crack and cooling system. If you have a portable scanner I would bring it along to see all the live data.
Also check for rust along the rocker panels and the rear bumper/upper control arm areas.
Poop
JasonStebbins is offline
post #3 of 11 Old 11-12-2013, 12:35 PM Thread Starter
ShugaWataPurple
Thanks a lot!
Hopefully this goes well!
post #4 of 11 Old 11-12-2013, 02:41 PM
zj97ltd
Where's the full sized spare?
zj97ltd is offline
post #5 of 11 Old 11-12-2013, 04:59 PM Thread Starter
ShugaWataPurple
It's in the trunk.
Also how much would a new radiator cost? Cause I bought it and it effin just blew on me when I was going up a hill....
I'm really hoping it's just a hose..
post #6 of 11 Old 11-12-2013, 05:07 PM Thread Starter
ShugaWataPurple
Ok so here's how it goes.
I filled up my truck
Was going up a hill and I couldn't get the car to go past 60 km
I went petal to the metal and nothing then all of a sudden it revved and hit 100. Awesome..
I turned and went on a straight road where it started smoking. I stopped and opened the trunk and coolant was leaking everywhere..
post #7 of 11 Old 11-12-2013, 05:20 PM
JasonStebbins
Could be a number of things. Fix what you know is wrong then see if it still does the same thing.
Radiator is around $80.00 at your local parts store with the online coupons. Check the upper and lower radiator hoses, then the water pump, then the heater core hoses, then the reservoir hose to the radiator cap. If all those are good, you need a radiator.
Poop
post #8 of 11 Old 11-12-2013, 05:28 PM
Snowfan2
They all do that.
Sorry you are having problems already. That will give you a greater sense of enjoyment when it's not having problems.
Snowfan2 is offline
post #9 of 11 Old 11-12-2013, 05:38 PM
rlcii77
Did it start smoking, or, was it steam? Did it downshift any while going up the hill? I've only seen a coolant hose or radiator rupture when the engine was getting hotter than normal, so, was it running hot or anything? Just trying to gain a clearer picture of the situation, don't mean to overwhelm you with questions...
'72 CJ5 Ren
'91 XJ, '96 XJ, '98 XJ
'94 ZJ, '96 Orvis ZJ
'98 Platinum 5.9, '98 Slate 5.9 (DD)
rlcii77 is offline
post #10 of 11 Old 11-12-2013, 06:01 PM Thread Starter
ShugaWataPurple
@rlcii7: no it wasn't running hot. When I went up the hill it wouldn't go past 60 and then afterwards the RPMs went really high and it picked up speed. That's when I turned and it started smoking hot white smoke and coolant was leaking everywhere.
Originally Posted by JasonStebbins
Could be a number of things. Fix what you know is wrong then see if it still does the same thing. Radiator is around $80.00 at your local parts store with the online coupons. Check the upper and lower radiator hoses, then the water pump, then the heater core hoses, then the reservoir hose to the radiator cap. If all those are good, you need a radiator.
I can't tell what's wrong unfortunately, I'm on the side of the road and I'm not very car savvy
post #11 of 11 Old 11-12-2013, 06:26 PM Thread Starter
ShugaWataPurple
Ok so update (sorry for the double posts)
I'm pretty sure it's the radiator, I just need to get it home right now! I'll keep you guys posted throughout the week.
Thanks for the help though!
