Firing up the ZJ again - JeepForum.com
post #1 of 16 Old 11-21-2012, 10:25 AM Thread Starter
93JGC5.2L
We'll I have a few days off an figure I'd see if I can get the Jeep running again. She's been sitting in the driveway for 4 years. I think the gas tank was mostly full when parked. I've got the battery on a charger. Should I just toss that in and fire her up or do you guys have any suggestions before I try and crank it over? I've heard trans fluid down the spark plug holes, etc but those were on inline motors, I don't think it will do much on the v8 (5.2L) with how the cylinders sit.. Oil was changed before it was parked and other fluids still look good. Thanks in advance!
93JGC5.2L is offline
post #2 of 16 Old 11-21-2012, 11:28 AM
RagTagSoldier
Might want to add water remover to certain fluids depending on how the look. But you said they look good so if everything looks to be in order (fluids belts shafts. Really anything that will be moving.) I would personally giver a go.
Sent from my iPhone using JeepForum and has probably been edited.
RagTagSoldier is offline
post #3 of 16 Old 11-21-2012, 11:31 AM
Scopez
1994 ZJ
Maybe siphon out the old gas and put some fresh in. Make sure oil looks good. Check hoses for cracking/dry rot.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #4 of 16 Old 11-21-2012, 11:51 AM Thread Starter
93JGC5.2L
I'd love to siphon out the old gas but I don't really have a place to store 20 gallons of old 87. Good call on the hoses. I need to clean a lot of leaves and pine needles out of the bay so I can do that when I'm in there.
post #5 of 16 Old 11-21-2012, 11:56 AM
Scopez
1994 ZJ
Hmmm. Got 20 milk jugs? Lmao. Maybe just dump some octane booster in there and rock the jeep side to side so it mixes alittle.
Turn the key on, let the fuel pump prime for 3-5seconds, try and start the Jeep but only bump it, don't hold the key forward. Do that a couple times so fuel is in the fuel rail. Then start the Jeep. Make sure the battery is good and charged.
Scopez is offline
post #6 of 16 Old 11-21-2012, 12:16 PM Thread Starter
93JGC5.2L
I also read someone suggested disconnecting the coil and cranking the key a few times to prime the oil system. I guess by biggest fear is breaking the rings if they have rusted to the cylinder wall. IIRC, it still has a bad plenum gasket, maybe there was enough oil in there when I parked it they should be ok? lol
post #7 of 16 Old 11-21-2012, 12:18 PM
Scopez
1994 ZJ
I have zero experience in doing that. My ZJ has sat for 8months without starting. But I'm only at 107k miles. How many do you have?
Scopez is offline
post #8 of 16 Old 11-21-2012, 12:22 PM
ramthis426
2005 WK
how about some photos
05 3.7 wk QT1,2.25 Old Man EMU,255/75/17 GY silent armors,call of duty black moabs,Spidertrax
1.5,Pinch weld & rear fender mod,hypertech max energy.1992 jeep xj larado 4.0,4.5 rought country lift, coustome built rear bumper with tire swing soon to be on 33s
ramthis426 is offline
post #9 of 16 Old 11-21-2012, 05:50 PM
Nejeep
Or better yet a video so we can hear all the strange noises it makes
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #10 of 16 Old 11-21-2012, 06:20 PM
RagTagSoldier
win
post #11 of 16 Old 11-21-2012, 07:47 PM
G-Man2
I think you will be asking for trouble if you do not get the old gas out first. It will likely be gummy and cause trouble with the entire fuel system if you try to run it through.
G-Man2 is offline
post #12 of 16 Old 11-22-2012, 10:44 AM Thread Starter
93JGC5.2L
Pulled the plugs and borrowed a friends bore scope. Plugs look good and the cylinder walls are clean. She's got 73k original miles. I'm expecting a lot of smoke. If it kills the motor, the whole thing is going to get scrapped. The body is worse than I remember. Part of me says fix it part of me says move on. Surprisingly the gas still smells like gasoline I'm throwing a battery in it and turning the key.
post #13 of 16 Old 11-22-2012, 10:57 AM
jt_armstrong
1994 ZJ
If its not too late i would do as has already been suggested and pull the coil lead and crank her first. Check that you have oil pressure. When you do, reconnect the coil and go for it. I do this regulary with the jeep i have in Sweden. She always starts like i had just turned her off.
Dont forget the video.
jt_armstrong is offline
post #14 of 16 Old 11-22-2012, 01:45 PM Thread Starter
93JGC5.2L
It's alive! I primed it by pulling the coil like you guys said. Also, it wouldn't start in P but it does in N so I'm thinking there might be a bad switch somewhere on the shifter. And it needs a new right front brake hard line, the pedal went straight to the floor once the booster got vacuum.
post #15 of 16 Old 11-22-2012, 03:04 PM
1stblack97ZJ
probably the neutral safety switch.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
