Quantcast Fire in my 5.9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Fire in my 5.9
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 06-16-2008, 11:56 PM   #1
Elkaholic
NMElkaholic
Elkaholic's Avatar
Fire in my 5.9
Not sure what happened?? Started the Jeep up this mornin to go to work, about halfway to work i start smellin electrical burnin??.. I get to work pop the hood and don"t see anything obvious....
I come out for break around 2:00 and I see this.....
A fire started in my engine!!! smoke and flames burnt my hood...
so then I open it and find this!!
Has anyone ever seen anything like this???
I have not looked into it to much yet..... looks like it might have started at my main positive battery cable?? what could cause this???
even melted my new battery!!!
any Ideas???
Thanx.....
98 5.9, Platinum 4.5 RE SF all adjustable arms, RE Monotube Shocks, Carolina front drive shaft, Pro Comp Extream Alloys Stryker's, 285/75/16 BFG's KM2's,Stage 1 rock sliders,Confer roof rack,Warn XD9000i winch, and lot's more goodies..
Elkaholic is offline   Reply With Quote
Old 06-16-2008, 11:59 PM   #2
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
HOLEY CRAP!!!
wonder how it happend.....
sorry to see that happen dude...
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/
5.9 ANDY is offline   Reply With Quote
Old 06-17-2008, 12:03 AM   #3
Elkaholic
NMElkaholic
Elkaholic's Avatar
It really bummed me out!!! I was fixin to start addin all my goodies on it, then this happened!!! now i have to fix all this stuff before i start my lift etc... it actually started and I was able to drive it home......
Old 06-17-2008, 12:05 AM   #4
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
where did you get that battery terminal? i need one like that...
Old 06-17-2008, 12:07 AM   #5
semperfismhs
better check your fuses b/c it looks like that box got burnt. fuses no likey fire
semperfismhs is offline   Reply With Quote
Old 06-17-2008, 12:07 AM   #6
Elkaholic
NMElkaholic
Elkaholic's Avatar
I got them at Auto Zone... $25.00 for the set.
Old 06-17-2008, 12:09 AM   #7
Elkaholic
NMElkaholic
Elkaholic's Avatar
yea... I am gunna have to replace that fuse box.... need to get it lookin like new again... really sucks!!! could something have been drawn current thru that cable and it got so hot it started a fire???? I am puzzled!!!
Old 06-17-2008, 12:09 AM   #8
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
ok, now... back to topic.... i see you added some wireing, are you sure you had it all good, and your wiring could not have sparked it off?
Old 06-17-2008, 12:11 AM   #9
Elkaholic
NMElkaholic
Elkaholic's Avatar
Only wire I added was a monster cable and fuse for my amp... but that was a few months ago. and have not had any issues with it??? just happened out of the blue!!!
Old 06-17-2008, 12:13 AM   #10
semperfismhs
to the OP, have you recently changed your oil or had it changed by someone else. because if by any chance some of it spilled somewhere then your wiring, as stated by 5.9 Andy, could have started it to burn........
Old 06-17-2008, 12:26 AM   #11
Elkaholic
NMElkaholic
Elkaholic's Avatar
No.... no oil drips... I keep the engine really clean... cain't tell from the pics, cuz the fire made a mess.
Old 06-17-2008, 12:39 AM   #12
JeepOrvis97
One of 2733 :)
JeepOrvis97's Avatar
Are you completely sure of that amp wire not being the problem, it looks close to the exhaust, the insulation could have melted and arced, is the fuse blown?
My Classifieds
JeepOrvis97 is offline   Reply With Quote
Old 06-17-2008, 12:43 AM   #13
GibsJeep
To me it looks like it started from either the battery's positive cable or the cable going into the fuse. Hard to tell though .
Definitely find out where that started to prevent it from happening again.....Good luck.
My 05 TJ
GibsJeep is offline   Reply With Quote
Old 06-17-2008, 01:07 AM   #14
-Joe-
All of those wires carrying positive current should have had more insulation/wire looms on them, if they didnt before the fire. If any of them were rubbing on any metal parts and broke the insulation it would have shorted out.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Old 06-17-2008, 01:11 AM   #15
jeepheller98
what size fuse are you running to the amp cause if its like 80 amps or something high i could still draw enough current/heat to catch fire but not blow the fuse.. is your remote wire to the amp fused? i forgot to fuse my remote wire and it shorted and almost set me on fire
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline   Reply With Quote
Glock Forum
