Quantcast Finishing up lift questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Finishing up lift questions
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 03-21-2007, 01:41 PM   #1
TheAngus
hey guys, im almost there with my claytons front kit and 4.5 kit
my problem right now is i cannot unscrew the brakeline on the front passenger side to put on the extended lines everytime i try to get a wrench on it it just strips it more, ive hit it with pb blaster many times and it has sat overnight
what do i do now???
once i get this line on i can go to the shop and get the crossmember welded and put the arms on and take her in for an alignment
1998 ZJ Limited 5.9L
l Vortech Supercharged w/ Meth Injection l SCT, 42lb Injectors, 2-Bar MAP, Walbro 255 l Kolak 3" Exhaust w/ DMH E-Cutout l KOR Steering Brace l KOR TB Conversion l Addco Swaybars F/R l JKS Rear TB l ORO U-Turn Steering w/ OME stabilizer l RE 4.5" Springs and Monotube Shocks l IRO Rear CAs l Firestone 31x10.5 MT l Kolak Ignition Upgrade l Clayton Front Longarms l
TheAngus is offline   Reply With Quote
Old 03-21-2007, 03:52 PM   #2
UKFan4Sure!
From your picture, it looks like the bracket is attached with a torx bolt. Can you remove it so you can lower the bracket to get a better angle of attack on the cable?
Just a thought?
UKFan4Sure! is offline   Reply With Quote
Old 03-21-2007, 03:54 PM   #3
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Get a special brake line wrench. They are designed to grip more of the nut then a regular open ended wrench.
ArloGuthroJeep is offline   Reply With Quote
Old 03-21-2007, 04:01 PM   #4
Ds4x4
Muhahaha... those things are EEEEVVILLLLL!!!! yes you need to get a wrench for the brake line.. theres a special wrench for a reason... it should still work after you screwed it up a little..
You know if you take it to a shop they'll charge you double for screwing it up...
1996 ZJ Orvis Edition,V8 5.2L
Tow & Skid Package, FM 40,44a - 3.73, NP249
265/75/16 Destination M/T's, JKS Discos, UC; Dual Intake;Red Top;
OME Stab.; Rustys 2" BB + shocks, xtreme hi-lift, Kennesaw Rear MultiCarrier
Proud To Be A FF/EMT/Police/Military Club Member #15
Ds4x4 is offline   Reply With Quote
Old 03-21-2007, 05:05 PM   #5
Katesdad
Katesdad's Avatar
Brakeline wrenchs kick butt.
If all else fails unhook the other end and just make a new brakeline.
Katesdad is offline   Reply With Quote
Old 03-21-2007, 06:30 PM   #6
TheAngus
alright thanks
i figured id need some special tool like that, funny thing is the other side unscrewed without any trouble whatsoever
ill post back if i have any more problems with the little bugger
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
