#16 | ||
Luck favors the prepared
#17 | |
I have a modified 1999 WJ and a stock 2001 WJ Tread Lightly Pictures PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! ! |
#18 |
bump
kuyfr9f
#19 |
Mr. Hyde!
It needs to be rolling to engage the 4wd modes most of the time. If the internals aren't lined up, then it is just a spring pulling them into the correct position but they won't mesh until you have the internals rotating.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#20 |
this might be a dumb question but it is in 4lo right? I know that on my 242 if its in 4hi it will send the power to the axle that has less resistance. therefore you will not move in 4hi but should in 4lo
#21 | |
Question is, is there more to the gears meshing than the simple hand check that I am doing? Do I have to get the jeep rolling down my street to engage the 4wd?
#22 | |
I do need to be rolling to engage 4lo. Could i drive in front wheel drive (missing the rear DS) in FULL TIME? I just need to see if this case works before I cut the DS myself.
#23 |
that should be possible to drive in 4lo without the rear ds but I'm not sure if it is recommended. I don't know that it would hurt anything except for the fact that you would only be able to go about 30mph
#24 |
Living dead mod
i would have thought the output shaft would be where you get the issues and not just the tailcone being in the way.
'97 zj 5.2, some stuff, some other suff, and some things that even work sometimes. |
#25 |
Mr. Hyde!
Drive in 4wd part time with just the front shaft and that'll work.
#26 |
Thats the problem the jeep doesn't move. I fell the trans shifting and there is resistence in the drive shafts but the jeep doesn't move when i put the trans and t-case in any of the positions. IS the t-case broken or what am i missing?
#27 |
wont the tcase fluid come out if you drive it w/e out the rear shaft?
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds |
#28 |
Mr. Hyde!
Not on a WJ - they have a sealed rear tailcone.
#29 |
I fit almost 2 qts of ATF+4 in the t-case, is that too much?
Are the trans output splines not mating up to the t-case?
#30 |
Hey just got back in to town. Any luck with this swap yet?
The grinding when in park and no movement when in 4wd is a concern. Did you get a chance to look inside the case to see if anything is broken? Maybe the linkage is just not adjusted properly? Anyways, I can tell you that slip part will be a real big PITA to cut into. That metal is hard and will chew up blades quickly. Not to mention you would have to polish up the other side to get rid of the rust so that it doesn't grind down the TC seal. I will be free tomorrow earlier on in the day so gimme a call if your free and need a hand for a bit. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
