finding the source of a coolant leak - JeepForum.com
post #1 of 4 Old 08-16-2009, 04:18 PM Thread Starter
tfgnt16
2009 WK
For the last few months I've been slowly loosing coolant out of the reservoir bottle and haven't been able to pinpoint the leak. I've eliminated the head gasket as a problem. I recently noticed a small stain that would appear under my WJ after a drive.
Got down and it smells like antifreeze... I'm guessing water pump but can't really see where it drips from. I don't think it's the radiator either, the drip is behind where the radiator is located. Anyone have any ideas?
2001 WJ Laredo 4.0L - Sold!
2009 WK Limited 5.7L HEMI
tfgnt16 is offline
post #2 of 4 Old 08-16-2009, 06:05 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Check real good around the thermostat housing. I had a small leak there that would drain my overflow bottle in about a month.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #3 of 4 Old 08-16-2009, 07:38 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Borrow or rent a pressure tester and you should be able to find the leak pretty easy. Under pressure the leak will usually start to push enough fluid out you will see and or hear it.
WiCkeDuDe is offline
post #4 of 4 Old 08-16-2009, 08:17 PM
elmer_fud
check the water pump, hoses, and thermostat. try and follow the fluid up and see where it is leaking from
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
coolant leak JD37055 ZJ Grand Cherokee Forum 5 11-29-2009 05:18 PM
Help finding leaking coolant dmm219 ZJ Grand Cherokee Forum 8 06-07-2009 06:35 AM
Help identifying source of coolant leak SouthPacific ZJ Grand Cherokee Forum 6 11-08-2007 04:07 PM
95 5.2 coolant leak help ed. ZJ Grand Cherokee Forum 1 09-13-2006 08:12 AM
Coolant Leak Mikey2 ZJ Grand Cherokee Forum 2 10-27-2003 09:37 AM
