finally pinpointed my oil leak - JeepForum.com
post #1 of 8 Old 11-21-2005, 04:15 PM Thread Starter
K-Pax
K-Pax's Avatar
hey guys, i finally got to the bottom of my oil leak problem. my rear main seal is leaking. i checked around and found a motorsports place that will repair it for $267. i've never had anything like this done and wanted to ask you guys if this sounds reasonable.
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
K-Pax is offline
post #2 of 8 Old 11-21-2005, 04:38 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
A search Bought up the following if you're looking to do it yourself:
http://www.jeepforum.com/forum/showt...rear+main+seal
Woody claims $250 isn't a bad deal...
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 8 Old 11-21-2005, 05:13 PM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
How bad is it leaking (1 Qt/week?)? how many cans of oil can you buy for $267? 100 qts? How much are willing to pay to keep that 100 qts of oil from leaking into the environment?
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #4 of 8 Old 11-22-2005, 12:07 AM Thread Starter
K-Pax
K-Pax's Avatar
ok.......everything i've read so far that sounded simple to repair myself has turned into a nightmare lol. as far as how much oil i'm losing, i usually have to put about 2 qts/month in. i'm working on sealing all leaks, to clean the undercarriage of any oil/grease. i'm doing this for when i feel like crossing a creek, none of the junk gets in the water. i started to cross one the other day, but decided against it because of the oil leak.
there is enough pollution in our water systems from all the chicken houses we have here as it is.
Kevin's rig:
2" budget lift
pro-comp steelies
JKS quick discos
K-Pax is offline
post #5 of 8 Old 11-22-2005, 12:32 AM
gdupjeep
Cost of oil
Forget the cost of oil. In my case, I didn't want my damn garage floor stained to hell. I think $267 is a pretty good price. I was quoted about that, but it turned out it was my valve cover gasket, not the rear main seal. Good luck with the fix.
gdupjeep is offline
post #6 of 8 Old 11-22-2005, 01:51 AM
OlllllllO Jeep1
$267 isnt too bad that is about the cheapest price that I have heard. Parts will cost you around $15 bucks for the seal and another $15-25 for the oil pan seal. So if you want to save yourself a couple hundred bucks to spend on something else for your Jeep, like gas then do it yourself. I did my Wrangler 4.0 a while back and it took a few hours. Just make sure to spray all the oil pan bolts with PB Blaster a few days before bust them loose with a breaker bar and if you have air tools use them after they are loose just to save your arms as there is about 28 bolts on the pan. I would advise getting a brass punch to remove the old seal. At the time I couldnt find one so I just bought some brass rod and turned it down on the grinder, to the size I needed.
It really isnt that hard of a Job. Seeing that you have a garage that makes it that much easier. If you have another vehicle just tear it apart one day and re-assemble it the nest.
Just make sure that it isnt your vavle cover gasket. the oil could run down and appear to be the rear seal. It is much easier to replace the vavle cover gasket.
OlllllllO Jeep1 is offline
post #7 of 8 Old 11-22-2005, 09:04 AM
ArloGuthroJeep
Mr. Hyde!
post #8 of 8 Old 11-22-2005, 11:19 AM
PlatinumZJ
PlatinumZJ's Avatar
Good, keep it clean. I work for a Co that does environmental engineering. Oil and gas can linger in the ground (if undisturbed and away from oxygen) for 40-years. Then some poor scmuck gets stuck with a cleanup bill in the $,$$$,$$$s for a spill caused by someone else, generations ago. No wonder the lawyers are running amok.
I Know -
Doug
Links:
for ZJ & WJ stuff,
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 05:58 PM
2003 JGC I6 codes 442 medium leak and 455 large leak samsdad ZJ Grand Cherokee Forum 0 08-28-2007 12:17 PM
Finally found my coolant leak. 95gc ZJ Grand Cherokee Forum 3 08-18-2007 07:09 PM
fron driveshaft join leak and pinion seal leak. GRDCHRKE555 ZJ Grand Cherokee Forum 1 12-12-2006 09:10 PM
engine light - Evaporative Emission Control System Leak Detected (very small leak) sanboy ZJ Grand Cherokee Forum 3 03-14-2006 10:42 AM
