Filling the Transfer Case...questions
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Hello all, you been great help in dealing with my TC and I just have one more question for ya.
On the back of my TC #242 I noticed two possible screws, one above the other to fill and drain the TC. Question: Is the bottom one to drain and is the top one to fill? This seems the ONLY logical choice to me, but I'm just making sure. Also, isn't there a special tool I have to get in order to get the ATF+3 pumped in there and fill it up with the 1.5 quarts? Is there any additives I should/could add to the TC while doing this job? Thanks all, you've really been a big help to me on here.
#2 | |
You've got the plug thing figured out, no problems.. No special tool required, though you could go get a fancy pump to do it, I just stick the nozzle of the bottle in the hole and squeeze the gitty-goo out of it. Then when I get the second bottle squeezed down, I pour what's left in the first bottle into the second bottle, and go at it again.HTH
Warren Black 1996 5.2L ZJ Limited |
#3 | |
I used a long funnel and still managed to make quite a mess. Next time I do it Im gona use some kinda tube,, there has to be a cleaner way..
97' ZJ Loredo 5.2 Quadra-Trac |
#4 |
The top of gear oil bottles are handy for that. Just screw it on the atf+3 bottle and shoot and sqeeze.
[SIZE=7][B]5.2[/B][/SIZE] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
