#1 | |
Filling with gas
so latley when i have tried to fill my tank up it just wont let me. when i put the fuel pump handle in and squeeze the trigger it almost instantly clicks and stops putting fuel in my tank. at first i thought it was just that pump so i have gone to 4 different gas stations and 5 different pumps and it does it every time. it will, within 2 seconds shut the fuel off. it gets really annoying because i have to hold it on almost a low/medium pressure to put it in. is there anthign i can do or do i just have to deal with this forever now
Thanks in advance Ted
1998 Jeep Grand Cherokee 5.2L 2"BB 31/10.50/15 Revo's K&N FIPK 1.25 in. Front Addco MX-6 Shocks 242 Swap Kolak Exhaust Future Mods: not sure yet... Broke *** student with no money...... [B]If it won't budge, get a bigger hammer, if it breaks in the process it needed to be fixed anyway.[/B] |
#2 |
Sometimes a similar thing happens to mine. Like, I once had to re-start the pump 4 or 5 times to get 14 gallons. Sometimes it'll be fine and sometimes it'll stop a little early.
I'm pretty sure that the fuel gauge(or whatever it's called that checks the level of the gas) is just sticking. |
#3 |
Mine does that sometimes, I find it can be cured by not sticking the gas nozzle all the way in. I've convinced myself that its some result of gas vapor that somehow shuts off the pump. Give it a shot, works everytime for me.
#4 |
GSMW!
I'm not a fuel station expert, however it seems that if there is enough back-pressure the pump sensor is tripped. Do what the other person suggested and don't shove it down so far
Quick! You are almost out of gas! Oh an a note from Hunter: "Did you buy your 2007 Grand Cherokee Calendar from Blaine yet?"
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#5 |
I agree, sometimes I have to readjust the nozzle so I know the gas vapors can vent because of the new eco friendly nozzles. Think of it as a vapor lock in the filler tube and if you angle the nozzle handle down a little......well, your burping your baby as you fill it!
"If I can't buy it or borrow it, I don't need it" -1994 ZJ Lifted and Locked... -1983 CJ7 4.2ltr/Dana 300/Warn F&R bumpers...and some other goodies. D.W.A. (Death Wobble Anonymous) |
#6 |
i'll try and give that a shot tomorrow. it just is a real pain in the butt ot stand out in the cold and hold wait forever just to put 10 or so buck in the tank.
thanks ted
#7 |
Same thing is happening to me right now with my '93 ZJ. I had a ford ranger that would do the same thing and it turned out to be a hose on the inside of the filler that had come loose within the neck.
I tired to take apart what I could on the ZJ's filler neck, but I didn't see any obvious issues. I know it's not a gas station pump issue and I'm certain it didn't come like this from the factory. Anyone know how or where the ZJ tank vents? It sounds to me like the tank can't take the rate of flow that the gas pump is putting into it (air and gas fighting for the same space). |
#8 |
Well I have found that if you turn the handle to one side or the other it usually allows you to fill. you have to hold your hand at a weird angle for a few but it usually works.
#9 |
I just checked out a manual for a '98 and it looks like the fuel tank vent goes to the EVAP canister under the left headlight under the hood. I think when I get a second, I might check out that line and make sure it isn't clogged or damaged.
#10 |
Mine does that at most stations. No matter how close I stick the nozzle to the filler, it still shuts off. That's why I go to the same station nearly everytime, it works fine there. I just got gas a few minutes ago at some station across town, and the same annoything shut off thing kept happening.
Justin 1993 ZJ Laredo 5.2 V8 • 4" lift • 31s • JKS f & r track bars • JKS discos • Cragar Soft 8s • DT 3000s • OME Stabilizer K&N drop-in • Dynomax Exhaust • Hella 500s • Westin Safari Bar • KOR Radiator Support Dark Rosewood Jeep Club Member #5
#11 |
I ate what?
Everytime I fill up...I look like a crazy man out there molesting my gas tank with that pump, I ram it in and out several times until it stays on. I assumed it was the back pressure thing too. Normally I try to hold the hole open long enough to vapors out and then it won't shut it off, afterwards I feel dirty
Ken 99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers 2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85) 2006 Pontiac G6 GTP - (her's) 2001 Dodge Ram 1500 - CAI, Soft 8's, 31's 2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch 2006 Triumph America 900 - Full Dresser January 2009 Grand Cherokee of the Month (GCOTM)
#12 |
hmmm i just push it in and listen to music
works good On my moms when it does that it helps to not put it in far. It seemed like it would do it for a week or two then go back to normal.
Mitch 2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade |
#13 |
I get this sometimes when the pump is set to the fastest pump setting. I find if its set back to the second highest notch it works fine.
quoted: This mechanism has been around for a long time, so it is safe to say there is not a miniature camera inside the nozzle hooked to a microprocessor. It's purely mechanical -- and ingenious. Near the tip of the nozzle is a small hole, and a small pipe leads back from the hole into the handle. Suction is applied to this pipe using a venturi. When the tank is not full, air is being drawn through the hole by the vacuum, and the air flows easily. When gasoline in the tank rises high enough to block the hole, a mechanical linkage in the handle senses the change in suction and flips the nozzle off. Here's a way to think about it -- you've got a small pipe with suction being applied at one end and air flowing through the pipe easily. If you stick the free end of the pipe in a glass of water, much more suction is needed, so a vacuum develops in the middle of the pipe. That vacuum can be used to flip a lever that cuts off the nozzle. The next time you fill up your tank, look for this hole either on the inside or the outside of the tip. Heres some interesting things to: http://www.epa.gov/donttopoff/
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
