Fender trimming.... alittle advice needed - JeepForum.com
post #1 of 7 Old 07-05-2013, 03:35 AM Thread Starter
ErikTheRad
I've read alot lately about fender trimming to make room for larger tires. However, people do alot of different trimming on different parts of the fender lip/inner fender/bumper cladding. I have finally collected all the parts (I think) to do my suspension and I need to know from those with experience as to what and where I'll need to trim, if at all. I am installing OME HD springs and ProComp ES9000 shocks with new isolators at all 4 corners (thanks Kolak!), should net 1" to 2" of lift. I have a new set of 31" A/T's on stock Wrangler/XJ wheels with a 1.5" spacer for a total of 3.75" backspacing. I'm thinking I'll hammer down that inner fender pinch seam and maybe trim about .75" to 1" off of the fender lip front and rear, the part that curves under and looks like it could cut the crap outta the tire if it hits. I'd really rather not cut out any of the fender beyond the lip-- or in other words, I don't want to enlarge the factory fender well-- and I don't think I'll need to with this mild set-up.
Any advice? I know this is a common "lift" set-up, and I'm not real excited about having to trim too much. Please give me an idea what to expect without the obvious "put the tires on there and see" remarks. Lots of people have put 2" and 31's under their ZJ, theres gotta be a pretty wide consensus on the amont of trimming needed. This is a mild-to-intermediate off-road trail rig, not a Rubicon monster. I'd like to get all this done in the next few days and it'll be easier to do the trimming, if necessary, while everything is apart. Thanks for any help!
ErikTheRad is offline
post #2 of 7 Old 07-05-2013, 05:17 AM
AnotherRedZj
At 2" with 31's.......cut a small wedge out the bumber that's about 1.5 inch, wide from the bottom, to nothing at the first line or groove on the way up and 2washers in the steering stops.
AnotherRedZj is offline
post #3 of 7 Old 07-05-2013, 09:10 AM
BrandonsZJ
Fender trimming is not necessary. Just like AnotherRedZj said you just have to trim the bumper. You will not need the 2 washers in the steering stops because you will be using 1.5" spacers.
BrandonsZJ is offline
post #4 of 7 Old 07-05-2013, 12:06 PM
AnotherRedZj
Originally Posted by BrandonsZJ View Post
...You will not need the 2 washers in the steering stops because you will be using 1.5" spacers.
Oh yea....true statement^^^^
post #5 of 7 Old 07-05-2013, 12:17 PM
JohnnyZJ
Hammer in the pinch seam and call it good. Trim bumper as stated
07' JKUR rollin on 35s
JohnnyZJ is offline
post #6 of 7 Old 07-06-2013, 01:11 AM Thread Starter
ErikTheRad
The pinch seam is just the 12"-14" or so (from memory) seam in the rear of the front wheel well, correct? Trimming the lip on the inner edge of the fender won't be necessary even with the 1.5" spacers?
post #7 of 7 Old 07-06-2013, 12:05 PM
Myusername1674
When i did mine i hammered the pinch seem in, also i 'rolled' every lip on the fenders. Its better to do this imo and get that lip out of the way. I also had to hammer up some of the metal in the front since my 31s were hitting it.
It really is trial and error because some 31s are larger then others, go ahead and do the lift and cut what youve been told to, then do an easy test flex on a log or a ramp. Check if the tires hit anything, and hammer stuff out of the way as needed.
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
