Fault Codes, DTC Diagnostic Trouble codes ETC. - JeepForum.com
post #1 of 5 Old 07-16-2009, 01:09 PM Thread Starter
ef1992
I was told how to check for codes on the dual climate, but how and where do you find the codes for the rest of the truck? Do ALL he codes come up for the whole car when doing the dual climate, or is the dual climate check ONLY for a/c and heat?
Please help!
2001 Grand Cherokee Limited-4.7 V8-Quadra Trac II-Flowmaster Super 44 with 3" exhaust
ef1992 is offline
post #2 of 5 Old 07-16-2009, 01:36 PM Thread Starter
ef1992
This is super important guys please help me out
ef1992 is offline
post #3 of 5 Old 07-16-2009, 01:52 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Pulling the codes on the HVAC system shows only those codes. It does not show the OBD codes for the entire vehicle.
Here is how you pull the OBD codes:
Originally Posted by wjjeeps.com
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
http://www.wjjeeps.com/faultcodes.htm
Wheelin98TJ is offline
post #4 of 5 Old 07-16-2009, 01:55 PM Thread Starter
ef1992
Thanks!!!!
ef1992 is offline
post #5 of 5 Old 07-16-2009, 01:59 PM Thread Starter
ef1992
Reading from the link you gave me it said the codes will normally appear when the check engine light is on.
So if there is no check engine light, there are no codes???
My truck has no check engine light on, so does that mean Im code free?
ef1992 is offline
Diagnostic Trouble Codes for OBD II and Details yrkoverland WK Grand Cherokee & XK Commander Forum 21 10-23-2013 01:07 PM
'95 ZJ trouble codes and diagnostic question bobiam ZJ Grand Cherokee Forum 6 01-29-2008 12:04 PM
HELP! with ZJ diagnostic codes rockitman ZJ Grand Cherokee Forum 4 06-14-2007 08:57 AM
Diagnostic Trouble Codes 12 & 31 Saturdaynight ZJ Grand Cherokee Forum 4 09-21-2005 07:58 AM
