fan shroud removal - JeepForum.com
post #1 of 14 Old 06-26-2016, 06:15 PM Thread Starter
StridAst
1994 ZJ
fan shroud removal
Hey there. First, my apologies, I seriously lack search skills on this forum apparently. Can anyone help me out here, have a broken lower radiator hose. 94 zj 5.2
Trying to figure out how to remove the fan shroud to get at the hose. And my search attempts haven't been as helpful as I would like.
StridAst is offline
post #2 of 14 Old 06-26-2016, 06:33 PM
Uniblurb
Uniblurb's Avatar
Typically you have to remove the fan and take the fan/shroud out together. It's a little easier on the 4.0 since there's 4 bolts holding the fan/clutch on. Someone can correct me if I'm wrong but believe there's a big couple/nut on the 5.2 between the water pump/fan which needs loosened. And some with the 5.2 may be able to replace that lower rad hose by just supporting the fan shroud up with it against the fan. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #3 of 14 Old 06-26-2016, 06:34 PM
wingless
wingless's Avatar
1994 ZJ
The fan shroud has a removable lower panel, retained by two push-on umbrella fasteners and two integrated snaps.
For me, the "easy" way to remove the shroud is to first unscrew the large fan clutch nut, remove the two shroud nuts then remove everything all at once. The shroud is attached to the radiator w/ nuts at the top and settles into plastic crossmember tabs on the bottom.
wingless is offline
post #4 of 14 Old 06-26-2016, 06:47 PM
xcaliber81
Dude I'd rather take the fan shroud off a 5.2 anyday then my 4.0. On my 4.0 to get it out properly I'd have to unbolt the upper rad support to clear the studs on the water pump
xcaliber81 is online now
post #5 of 14 Old 06-26-2016, 06:54 PM
Dunebasher
Guest
Posts: n/a
Really? You must have aftermarket studs that are much longer than stock? Fan and shroud always came out together with no issues on my 4.0L.
post #6 of 14 Old 06-26-2016, 07:04 PM
kachink
I just did my rad hoses on my 5.2. It was not necessary to remove the entire shroud, just the lower panel that will come off from underneath (which is not part of the shroud itself).
kachink is offline
post #7 of 14 Old 06-26-2016, 08:08 PM Thread Starter
StridAst
1994 ZJ
Thanks to everyone! The hose is now replaced. Just have to go get some antifreeze to put in now.
StridAst is offline
post #8 of 14 Old 07-01-2016, 10:49 AM
Candymancan
Get yourself one of those little coolant testers at the store like $5. It tells you what the coolant is good up to as far as the freezing and boiling point, try to keep it at 50%
Candymancan is offline
post #9 of 14 Old 07-01-2016, 02:38 PM
GOLDWING
Try this, saves lots of cursing.
GW
2 '98 4.0 ZJs
Hers is stock, mine, OME shocks, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #10 of 14 Old 07-01-2016, 05:00 PM
wingless
wingless's Avatar
1994 ZJ
Cursing is not bad if done properly. Here is the expert!
wingless is offline
post #11 of 14 Old 07-04-2016, 09:19 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
The biggest benefit of an electric fan...it easily comes right out and even with it in, there is more room to work.
HighLonesome is offline
post #12 of 14 Old 07-06-2016, 07:37 PM
Candymancan
God i love the e-fan on the 5.9. 2 bolts. 1 plug entire thing pulls out lol. I hate the clutch fan on the wagoneer and 4.0. No room for my fat arms the blades squeeze them... and then tightening the bolts turns the pully so you have to grab it with the other hand to hold it
post #13 of 14 Old 07-06-2016, 08:25 PM
dellis
2005 WK
GW
That is an awesome idea!
1998 ZJ, 4.0 // 2005 WK Limited, 4.7 // 2008 KK 3.7
dellis is offline
post #14 of 14 Old 07-06-2016, 08:49 PM
GOLDWING
Thanks, it is not ideal for the purist, but mt knuckles bleed less and the fan comes off in half the time.
GW
2 '98 4.0 ZJs
GOLDWING is offline
