fan shroud problem - Page 2 - JeepForum.com
post #16 of 33 Old 03-28-2011, 10:36 PM Thread Starter
Corrupt
OK, maybe I exaggerated a little. It's around 4 inches from the blade to the fins on the rad. At idle I just don't believe it has enough to pull air through out the whole radiator. That's just a lot of room to draw air from on the sides of the radiator.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #17 of 33 Old 03-28-2011, 11:01 PM
Pugulis
I'm a little confused. What is the temp gauge getting to? Mine runs at just a hair above the 210 line all the time and this is normal. Are you thinking that this is overheating? The fan shroud will effect the temp a small amount, but not enough to make it overheat (unless your radiator is clogged). If it is overheating, check the water pump. It may "look" good, but that has nothing do do with operation. Remove the belt and see if the pump has any play in it. Also, are you sure you got the right fan clutch? Next time it does the overheating thing, get out and make sure the fan is actually spinning.
Pugulis is offline
post #18 of 33 Old 03-28-2011, 11:04 PM
Pugulis
One other thing. When you flushed the system, did you put a good 50/50 mix in? And is the overflow tank at the right level?
Pugulis is offline
post #19 of 33 Old 03-28-2011, 11:53 PM Thread Starter
Corrupt
Well, after we changed the t-stat and started her up and let her sit for a good 15-30 minutes at just idle, she slowly crept up until my idle speed bumped up a notch trying to spin the fan faster. This was before I changed out the bad fan clutch. I haven't let her sit that long again as I don't want to overheat her again so soon. I'll just wait till I get the shroud on, then I may let her idle for a while and see where she settles in at.
Corrupt is offline
post #20 of 33 Old 03-29-2011, 12:03 AM
Pugulis
I have to ask again. What temp is it getting to? Is it getting to the red zone? just above 210 is perfectly normal.
Pugulis is offline
post #21 of 33 Old 03-29-2011, 07:03 AM
PlatinumNiner
Wow you have a lot of room there lol. Ill post pictures of mine later. Different set up with the electric fan of course but it almost looks like the clutch fan wouldnt even fit thats how little room i have. With an aluminum water pump its very hard to tell age from looking at it. They look new forever as they dont rust. You sure you dont have a sticky thermostat? Just because its new doesnt mean its not bad.
PlatinumNiner is offline
post #22 of 33 Old 03-29-2011, 08:03 AM
KJK
You've already done everything else, now get the fan shroud so everything else can work for you at idle.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #23 of 33 Old 03-29-2011, 08:15 AM
speedbucket
stry to smoke a cig with your mouth wide open. thats the basic principal of not having your fan shroud on
your fan is doing nothing at idle or speed to pull air. if you took the blades off you probably wouldn't notice a difference b/c that shroud isn't there. the 5.2 isn't close to the I6 as far as cooling, so you cant compare them.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #24 of 33 Old 03-29-2011, 06:34 PM Thread Starter
Corrupt
That gave me a good laugh, but yea, I know what your talking about.
Pugulis, The temp gauge got up in between 210 and 260 and she started boiling out of my coolant reservoir. Even though going through an obstacle and putting the Jeep on "tilt" with the drivers side a LOT higher then the passenger side probably didn't help the situation. Since then I have done my best to not let her sit and idle until I get the fan shroud.
Corrupt is offline
post #25 of 33 Old 03-29-2011, 11:12 PM
Pugulis
The analogy isn't quite right. And as I said, the shroud will effect the temp, but not to the extent your talking about. Not unless your stopped in 90 degree weather. Also, I'm not comparing to my I6, I'm comparing to every car and truck I've ever driven. If you've got coolant "boiling" out the overflow tank and it hasn't even reached the red zone, something else is wrong. Of course replacing the shroud will help and may even hide the problem. But there is something else wrong. I'd start with the possibility that the thermostat is in backward (or defective). Next is that the coolant doesn't have a 50/50 mix. And then there's the possibility that the pump is shot. The final thing is that you may be looking at the beginning of a blown head gasket. In which case, having a missing shroud will effect it allot (but that's a worst case scenario.)
I'm still leaning toward the coolant mix and thermostat. If you get a new shroud and the problem goes away, cool. But I still think something else is going on.
Pugulis is offline
post #26 of 33 Old 03-30-2011, 12:08 PM
PlatinumNiner
Your right the 5.2 and 4.0 are totally different in terms of cooling. The 5.2 has really no issues staying cool yet the 4.0 LOVES to run hot and is harder to keep cool. If you can keep a 4.0 cool with no shroud you can keep a 5.2 cool just the same.
post #27 of 33 Old 03-30-2011, 12:18 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
lol, try a lowspeed climb of a long grade on a forest road around here. See how far you get without a shroud. If the shroud wasn't necessary, Chrysler would have omitted it. Get a freaking shroud.
Keeps the varmints on the run, boy
HighLonesome is offline
post #28 of 33 Old 03-30-2011, 12:31 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
^X2
There's nothing wrong with your radiator, thermostat, or water pump. You need to put the shroud on in order to let the fan properly pull air thru the radiator. Maybe the new fan clutch is an issue, but why are you diagnosing when you don't have a complete system? I'd also bet that your A/C doesn't work too well at idle, due to a lack of air flow across the condenser.
BTW: I don't think this is your problem (since you're OK at highway speed), but... are you sure the fins on the A/C condenser are clean and straight, so that they don't further block air flow?
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #29 of 33 Old 03-30-2011, 01:02 PM Thread Starter
Corrupt
Originally Posted by SJZ View Post
^X2
Yup, have taken a light on the backside of the radiator and looked through the front and could see that the fins are straight. I do live in Florida, and the day this happened the temps were up in the 85+. Since then we've had a cold front move through so it is now a little cooler outside and sitting in traffic the highest she gets is just under 210. I'm pretty sure it is the shroud and am in the process of getting one from someone through the forums. Have tried the junkyards around here and nobody has a 5.2L ZJ sitting around with a fan shroud in it.
Corrupt is offline
post #30 of 33 Old 03-30-2011, 02:12 PM
speedbucket
i thought it was good. non directional pull of air from around something your trying to pull air through is a pretty good analogy to me, and the OP got it so what else matters
Fan shroud for E-fan on ZJ 4.0 niles6284 ZJ Grand Cherokee Forum 0 01-30-2011 10:18 PM
HELP!!! 98 ZJ fan shroud overseasjeepn ZJ Grand Cherokee Forum 2 08-11-2010 02:28 PM
Anybody know where to buy a Fan Shroud for 94 ZJ? cory25 ZJ Grand Cherokee Forum 2 05-06-2010 06:17 PM
fan shroud, 5.2 ?? Stuart ZJ Grand Cherokee Forum 4 09-17-2008 11:41 AM
Fan shroud rubbersidedown ZJ Grand Cherokee Forum 1 01-10-2008 12:01 AM
