Fan shroud ? - Page 2 - JeepForum.com
post #16 of 17 Old 05-02-2013, 10:57 PM
jnicewan
Antifreeze is not just for winter, though it lowers the freezing point of water, it also raises the boiling point too. Antifreeze/coolant provides protection from corrosion and rust and fights mineral deposits from water. Another side benefit to anti-freeze is leaks, it doesnt evaporate and dry quickly plus it is dyed so unlike water it will leave more evidence behind when leaking.
A stronger water mix ratio will provide better heat transfer but I would at least try to run around 25-30% anti-freeze just for the other benefits. There are also additives you can put in the system in lieu of anti-freeze to supplement the water or supplement the heat transfer properties.
jnicewan is offline
post #17 of 17 Old 05-03-2013, 10:42 AM
dylantheheeler
Water boils at a lower temp than 50/50. I would use some antifreeze.
Edit: jnicewan beat me to it.
Sent from AutoGuide.com Free App
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
