Fan shroud ? - JeepForum.com
post #1 of 17 Old 05-02-2013, 07:07 PM Thread Starter
BuzzZJ9er
When I first started to check out the water pump I removed the fan shroud. While doing so I got frustrated trying to snake it out and broke the bottom off.
Once I replace the water pump (tomorrow) I would like to put this shroud back on. I have 2 questions about this.
1. Do I need a fan shroud for more than personal safety? My uncle was saying no fan shroud could cause the engine to over heat.
2.if I peice the shroud back together should I us little bolts or zip ties? I'm planning on drilling small holes in each peice for a place to attach the two.
BuzzZJ9er is offline
post #2 of 17 Old 05-02-2013, 07:11 PM
ZJNW
I would either spend $10 and go to the junk yard and get another im sure there are at least 5 zj in your local junk yard or drill small holes and drift stitch it back together.
1995 ZJ 5.2 work in progress
ZJNW is offline
post #3 of 17 Old 05-02-2013, 07:16 PM
riot1987
The shroud helps pull air through, making it cooler. Mine is zip tied, youll be fine with those if you have to use them
Build thread^^
riot1987 is offline
post #4 of 17 Old 05-02-2013, 07:17 PM
JasonStebbins
Get another fan shroud. It directs the air where it needs to go. Don't bother trying to patch that one up.
Poop
JasonStebbins is offline
post #5 of 17 Old 05-02-2013, 07:53 PM
dusterdude
Is this a one piece or two piece shroud?
dusterdude is offline
post #6 of 17 Old 05-02-2013, 07:58 PM
riot1987
Id assume it has the same shroud as a 5.2. Two piece.
Build thread^^
riot1987 is offline
post #7 of 17 Old 05-02-2013, 08:00 PM
dusterdude
Thought it might,in that case,zip tie it back together
post #8 of 17 Old 05-02-2013, 08:00 PM Thread Starter
BuzzZJ9er
It's a two peice and a 5.2. It's just a trail/ mud toy and I don't want to spend money on it if I can help it. My niner will take all the money it can get. Lol
post #9 of 17 Old 05-02-2013, 08:12 PM
jnicewan
I would say the shrouds are pretty important on all ZJ's, even if yours doesnt try to run hot, it just might without the shroud, especially in the hot summer months. If its a trial rig, I would think the shroud would be even more improtant since you will be seeing more slow speed driving where the fan will need all the help it can get to pull air through the radiator and not around it. Fix it, replace, rig it up but try to keep most or all of it on there.
jnicewan is offline
post #10 of 17 Old 05-02-2013, 08:23 PM
AnotherRedZj
I broke mine on one side doing the same thing. Two holes and a heavy zip tie holds it together good and helps when it needs to come out again too! Jus cut it and put another in when done. I will add that I have a real clean break so it might not work so well for you!
AnotherRedZj is offline
post #11 of 17 Old 05-02-2013, 08:24 PM Thread Starter
BuzzZJ9er
That's kinda what I wanted to hear. Guess ill zip tie the broken pieces back together as they are lower profile. It's a fairly clean brake.
On a side note the coolant that came out got contaminated wit dirt/ rust so I will be replacing it. I was wondering if straight water will help it stay cooler? This fall I would put some antifreeze in for the winter.
post #12 of 17 Old 05-02-2013, 08:36 PM
riot1987
I ran a bunch of water in mine for a bit one summer cause I had a really bad water pump leak. It doesnt cool any better.
Build thread^^
riot1987 is offline
post #13 of 17 Old 05-02-2013, 08:43 PM Thread Starter
BuzzZJ9er
Does it cool worse? Would be easier for the time being.
post #14 of 17 Old 05-02-2013, 08:49 PM
riot1987
If your 100% sure it wont freeze, it works. Not recommended but itll work.
Build thread^^
riot1987 is offline
post #15 of 17 Old 05-02-2013, 09:01 PM Thread Starter
BuzzZJ9er
I'm not worried about it freezing for a few months. wish it would stay in the 60/70 range all year.
