Famous Grand cherokee a/c leak - JeepForum.com
post #1 of 4 Old 09-24-2008, 11:04 PM Thread Starter
lebaneseshowoff
ok, i'm sure this topic has been beat to hell and back but i got the famous a/c leak on the passenger floor, and i don't know how to fix it. I'm sure i'm not the only person with this problem so if anyone can shine some light over here, it would be greatly appreciated!! Thanks in advance.
1998 Jeep Grand Cherokee Laredo L6
1995 Jeep Wrangler L4 - 3" BL, 33"x12.5" TSL Super Swampers, Home made Snorkel. More mods coming!! Sold!!
Now 2003 Dicrovery II J.R.U.
Cayman 4x4
lebaneseshowoff is offline
post #2 of 4 Old 09-26-2008, 08:50 AM Thread Starter
lebaneseshowoff
Alright, so.. i finally found th write-up. I tried to do it but it didn't quite work idk what happened it still leaks inside, is there a plan b for this? I try to stick a coat hanger in there and nothing, then i tried to use a "blow gun" and nothing so... any suggestions?
Cayman 4x4
post #3 of 4 Old 09-26-2008, 09:18 AM
boomersoonerGC
Mine was leaking from around it because the foam gasket was bad. I took it off and made a new one with some RTV and no more leaks.
boomersoonerGC is offline
post #4 of 4 Old 09-26-2008, 11:12 AM
alivenkickin28
you need to use an air hose from an air compressor and blow it all out good...then see if that stops it -- if you still get water in check that foam gasket that boomer just talekd bout
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
The Famous Grand Cherokee Electrical Problem trevtaylor ZJ Grand Cherokee Forum 19 10-01-2011 09:07 AM
Oil leak on 2002 Grand Cherokee Mike D ZJ Grand Cherokee Forum 2 01-29-2010 02:13 PM
'05 Grand Cherokee...Leak? DSimmon WK Grand Cherokee & XK Commander Forum 5 12-07-2007 11:42 AM
Water leak 2004 Grand Cherokee dely1644 ZJ Grand Cherokee Forum 6 09-10-2005 10:34 AM
Leak in exhaust manifold,96' Grand cherokee willsellout ZJ Grand Cherokee Forum 10 01-25-2004 07:01 PM
