Fake Bead Locks?s - JeepForum.com
post #1 of 7 Old 05-13-2013, 04:43 PM Thread Starter
SHOMurph
Fake Bead Locks?s
Hi All,
My ZJ is just my off road toy. I have 33s on canyons.
I've seen a guy wheeling a couple of weeks ago rub his tire against a rock and riped off the valve stem.
I am wheeling about twice a month now and don't want that to happen.
Would a set of fake bead locks protect the stem?
I appreciate it.
SHOMurph is offline
post #2 of 7 Old 05-13-2013, 07:38 PM
Crasher
When I went to a 17" steel D window wheel for my 35s, I welded on "Rock Rings" that strengthen the wheel for impacting a rock when aired down, but they also protect the valve stems.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #3 of 7 Old 05-13-2013, 08:24 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
there are a few options.
different wheels, like street-locks may help. or just steel wheels with rock rings welded on. even a simple metal plate around teh valve stem to protect them would help. Another solution is to re-locate your valve stem. weld up the hole it is currently in and re-drill it deeper into the wheel.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #4 of 7 Old 05-13-2013, 10:44 PM
riot1987
Where do you re locate? Deeper, like closer to the spokes?
This happened a few weeks ago when my old man lost a valve stem.
Build thread^^
riot1987 is offline
post #5 of 7 Old 05-14-2013, 02:51 PM
KingtheZJ
yes, they are called rock rings
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #6 of 7 Old 05-14-2013, 05:54 PM
paintballwannab
Wow...this is a fear I never had till now when off roading. Off to buy some spare valve stems.
paintballwannab is offline
post #7 of 7 Old 05-14-2013, 07:22 PM
underpowered
Farther back into the wheel, deeper. many guys who run bead locks do it for ease of adding air to the tires as the lock rings can make it difficult any ways.
I plan on doing it because i ripped a valve stem out while wheeling this weekend as well.
