failed emmisions... - JeepForum.com
post #1 of 12 Old 07-08-2011, 10:12 PM Thread Starter
metallica0682
failed emmisions...
ok so i failed emmisions for a DR-1220 defect number "The fuel tank level sending unit may display an inaccurate level" What is this? is it the fuel pump? need a lilltle help decoding the part I need to repair it...thanks
metallica0682 is offline
post #2 of 12 Old 07-08-2011, 11:04 PM
TheHalfWit
Since yours is a 96, this means you have to replace the fuel pump. The sending unit is a float attached to the fuel pump, and is non replaceable on 93-96.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #3 of 12 Old 07-08-2011, 11:06 PM
phitmein
phitmein's Avatar
that's insane ...
They won't pass your ride because your gas/petrol gauge may or may not be accurate ...
I would take it again and see if it would pass ...
Their machine may or may not be accurate too ...
They don't care over here wheather or not if you even have a gas gauge ...
Jeeze ...
Phit
phitmein is offline
post #4 of 12 Old 07-08-2011, 11:24 PM
zander21510
Alternatively, if its like Texas, some counties do emissions tests some don't...take a drive over the county line
zander21510 is offline
post #5 of 12 Old 07-09-2011, 12:11 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Chrysler didn't make an accurate fuel gauge between 1990 and now, even the replacements will often not show accurately or d do the chrysler standard random drop to empty trick.
ratmonkey is offline
post #6 of 12 Old 07-09-2011, 12:36 AM
phitmein
phitmein's Avatar
"Chrysler didn't make an accurate fuel gauge between 1990 and now"
GM either, for that matter ... I'm old school ...
From slap full to 3/4's, it seemed like killer mileage, but from there down it fell like a rock ...
Well not quite, but you know ...
phitmein is offline
post #7 of 12 Old 07-09-2011, 12:49 AM
newfieZJ
That was a "voluntary" emissions recall for 97 models . Apparently , they should have had it for 96 as well .
newfieZJ is offline
post #8 of 12 Old 07-09-2011, 09:47 AM
90lsturbo
i know here if your cel is you want pass i/m test for 96 and newer until you fix the issue throwing the light off
2006 dodge ram hemi -DD
1993 zj-sold
1981 cj5- traded
1984 cj7- the other mistress
#89 UJC
"Real men dont let their friends drive prius's"
90lsturbo is offline
post #9 of 12 Old 07-09-2011, 09:52 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I went cross eyed reading that.
post #10 of 12 Old 07-10-2011, 03:08 PM Thread Starter
metallica0682
sorry guys forgot to mention that this was for a 1997 grand not my 96 I don't know if that makes a difference or not....
post #11 of 12 Old 07-10-2011, 03:23 PM
airwolf9090
I hear ya mine is dang good on gas but the second it hits the 8th mark below 1/4 it drops like a rock
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #12 of 12 Old 07-10-2011, 05:47 PM
TheHalfWit
It does, the 97's have a replaceable float, but I'd say try to have it retested elsewhere first since like has been mentioned here Chrysler doesn't make accurate gas gauges.
Mine for instance is rock-solid about when its full on gas, or running on empty. In between its anyone's guess.
Calm. C.
Emmisions fail HELP !!! weberdm1980 ZJ Grand Cherokee Forum 23 01-23-2010 09:43 AM
starter replacement-ca emmisions applik ZJ Grand Cherokee Forum 1 10-11-2009 03:36 PM
GC's Bluetec engine fails EPA emmisions for 2007 zband ZJ Grand Cherokee Forum 11 08-30-2006 10:19 AM
Failed Emmisions for high CO greasefingers ZJ Grand Cherokee Forum 22 05-20-2006 06:46 PM
77 cj(no emmisions), 02Laredo(emissions leak)?! dave ollllo ZJ Grand Cherokee Forum 2 05-14-2005 07:16 PM
